I want this lift... but not without your input!!! "Toytec"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TacoBeav, Sep 14, 2011.
  1. Sep 14, 2011 at 9:09 PM
    2011TacoBeav
    2011TacoBeav [OP] Well-Known Member
    Bret
    Oregon
    2012 Sr5 v6 auto DCSB
    Self made rear bumper Colormatched Bush Wackers CB Center console lock box Camo seat covers Weathertech Digi blk Bilstein 5100s set at .85 Eibach coils LR UCAs Rear 1.5" block
    Hey ya'll!
    I'm literally about to buy this lift from Toytec... I would really like a 2-3" lift and even though it will spend most of its life on the street.. I refuse to have a truck that is completely incapable of performing its regular duties! :)
    So I am avoiding going with spacers... etc. and going with this lift. I'm looking for comments/replies from those with experience from the brand or better yet this particular set up.
    Addtionally, I am interested in input as to whether or not I should go this direction and purchase them now... a whole month before I plan to purchase my wheel/tire set up. and just rocking stockies... haha. or waiting it out...
    Any comments are very much appreciated!!
  2. Sep 14, 2011 at 9:13 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    It's completely up to you as far as buying before the wheels/tires; I ran with stockies for a few weeks before my tires came in too
    And that's a great lift. Basically exactly the same as what I'm running and I've never had any problems. *knock on wood.
    Handles on road great, even better off!
    :thumbsup:
  3. Sep 17, 2011 at 4:36 PM
    mrjhnguyen
    mrjhnguyen Active Member
    houston, tx
    08 tacoma trd
    I'm planning on the same setup and was going to ask the same question... I'm already running on 265/70/17 Toyo open county a/t with spacers... Can't wait
  4. Sep 18, 2011 at 9:31 PM
    2011TacoBeav
    Bret
    Oregon
    mrjhnguyen what kind of spacers are you running?
    those the stock trd 17" wheels?
  5. Sep 18, 2011 at 9:53 PM
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    I will be going with the same set up and adding LT UCA's when I buy my 2011/2012 TRD OFF ROAD not sure yet. I am going to run the stock tires and wheels for a while untill I can fork out some more cash for some bigger tires. I may put on some 1.25 wheel spacers to give it a little wider stance.
  6. Sep 19, 2011 at 1:53 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    You will have maxed up travel if you set at 2.5-3inches of lift. Your rubber grease boots will take a toll sooner or later. Purchase a set of used coilovers. There was a set of FOX RR 2.0 coilover in the for sale forum i saw, don't know if they are still there. Not to mention you can sell your old shocks. Add a leaf is ok for like 1.5 of rear lift, and the 5100 are good for that height but not any higher. If you go up to 3inches in the rear you'll need 5125 as they are longer shocks. Spend the little bit of extra money on the front suspension and you'll be even more pleased, not to mention you can adjust your front height with a spanner wrench.
  7. Sep 19, 2011 at 1:58 PM
    mrjhnguyen
    houston, tx
    08 tacoma trd
    spidertrax 1.25 and yeah stock 17s... when i bought the truck thos were what it came with so i was pretty happy... with the spacers it pokes out about an inch
  8. Sep 19, 2011 at 2:24 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    its a great kit. I have the toytec ultimate lift on mine
  9. Sep 19, 2011 at 3:20 PM
    tacojpklx
    tacojpklx Well-Known Member
    eric
    michigan
    '10 AC OR, Magnetic Gray, 6spd
    toytec lift (eibach, bilstein 5100 at 0, Recall springs +Sumo Springs) seat covers, tint, weathertecs, shrokwork sliders, brute force rear bumper, in bed hi lift.
    I have this kit on my '10. Couple things i noticed. 1) Make sure you get the 1/4 spacer sold separately to correct the taco lean 2) I set it at 0 and the cv angles looked good. I wouldn't go any higher. It was about 1.75 lift on my truck. 3) The rear lift was more than advertised. I was no tsb and went with the 2 aal; option. At first it was 3 of lift, but now a year later is settled down to maybe 2.5. Keep in mind this was on a fresh truck, no heavy loads/towing, and I still have only 2,300 miles after a year now. Doing it over, I might consider the 1.5 aal. 4) I put in the carrier bearing spacer after-the-fact. If i were you I'd put it on. The spacer seemed to help my take-off shudder, but the biggest help were the new duratracs. 5) Didn't see any problem with the shocks being too short. Don't know what that's all about? Seems to flex and compress fine to me. 6) Expect to have to have it realigned a couple times. My shops first shot at it wasn't acceptable, but they got it right the second time. Overall, I would do it again. Truck rides and looks better than stock. I look for crap pavement and bumps to hit on purpose. Never had a vehicle that felt so composed/solid on frost heaves and potholes. Good luck.
  10. Sep 19, 2011 at 3:22 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Im running that kit and its simply amazing.
  11. Sep 19, 2011 at 4:50 PM
    2011TacoBeav
    Bret
    Oregon
    Hey thanks for the input!
    The kit comes with the diff drop... so this should help with the cv angles correct? did yours not come with the drop.
    Also the kit comes with the 1/4 inch spacer to eliminate drivers lean
    I'm going to be running duratracs too! haha. what size you go? i wanna do the 265/75 but don't want em to look to small
  12. Sep 19, 2011 at 4:51 PM
    2011TacoBeav
    Bret
    Oregon
    WHat height setting are you running?
  13. Sep 19, 2011 at 4:54 PM
    2011TacoBeav
    Bret
    Oregon
    spidertrax are spendy... $200 for all four corners... do you know of any less expensive but comprable in quality?
  14. Sep 20, 2011 at 9:02 AM
    tacojpklx
    eric
    michigan
    Yes, it comes with the diff drop, but i didn't put it on. Heard mixed results on it's effectivenss and looking at it and driving it i said - nah. Ur right, I remember the spacer came with the kit, forgot about that. My shop forgot to put it on at first, so be explicit. Also, print off the directions off toytecs website if you have a shop do it. All told it cost me $450 i think. I am running 265/70/17. Up from my OR rims which are set aside for now. They won't look too small, they are what it should've come out of the factory imo.
  15. Sep 20, 2011 at 5:21 PM
    2011TacoBeav
    Bret
    Oregon
    Yeah... I'm definately installing them myself. I figure if I have the mechanical ability to rebuild an entire accord engine and build my own sliders for the Taco I should be alright with a fairly simple suspension lift... hopefully! haha
    Maybe I should take my savings from self intsal and go with the $850 kit... still trying to figure out the explicit differences. and whether or not it'd be worth it
