I want to fit a 35" spare while keeping mild performance in mind. Thoughts/Ideas?
Discussion in 'Suspension' started by desertjunkie760, Dec 2, 2018.
  1. Dec 5, 2018 at 4:14 PM
    #61
    desertjunkie760
    desertjunkie760 [OP] @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    @YumaTRD and I were actually talking about that late last week. He has a 35" spare that we were playing with and that was one of the spots we discussed. Definitely doable but the tire would have to sit on the passenger side due to the location of the gas tank. I would also have to re-route the exhaust, which isn't really that big of a concern.
    I think the major issue was deciding how to remove the tire when loaded up. Definitely not out of the realm of possibility.
    That was also a topic we discussed. Could compress the tire a bit being I have OBA to save a little space.
    eccracer104 likes this.
  2. Dec 5, 2018 at 4:20 PM
    #62
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Can save you some space if you’re really tight for room.
    Arcticelf likes this.
  3. Dec 5, 2018 at 4:30 PM
    #63
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    I would recommend whatever you do, be sure to plan for a 37 in the future, you'll likely regret it down the line if you make the holder/design too tight to fit an extra 2 inches of diameter.
  4. Dec 5, 2018 at 4:35 PM
    #64
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Airing down would work, but ratcheting it down to 32" would most likely cause a flat spot over time on the wall of the tire. Airing down was mostly for an inch or less of clearance issues.
  5. Dec 5, 2018 at 5:28 PM
    #65
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Probably easier for me because I have a DCLB. If you just make the hole a bit wider than the tire, it should be able to flop down flat onto the bed without too much hassle.
    Design it for a 35, then an aired down 37 will fit. That was my plan anyway. Though my problem with that is I hate my stupid TPMS that has a sensor in the spare... Guess I gotta just pull that LED.
    37 is definitely the new 35
  6. Dec 5, 2018 at 6:28 PM
    #66
    tetten
    Andy
    Socal
    Tell me about it, every Instagram whore that's never done a trail harder than a fire road is putting them on.
  7. Dec 5, 2018 at 6:38 PM
    #67
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I resent that as I plan on going to 37's on my next set of tires and I have an instagram. Follow me @
    tetten[QUOTED] likes this.
  8. Dec 5, 2018 at 6:41 PM
    #68
    tetten
    Andy
    Socal
    :rofl:Pretty sure I already do. And I am putting on 37s too. But last time I checked, we actually use our big ass tires.
    snowsk8air2[QUOTED] likes this.
  9. Dec 5, 2018 at 6:43 PM
    #69
    WormSquirts
    Braeden
    BC
    dammit, guess my plan for 37's is out the window... Gotta do 40s on stock IFS now. Thanks guys.
    Arcticelf, snowsk8air2 and tetten like this.
  10. Dec 5, 2018 at 6:58 PM
    #70
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I'm just waiting to go big enough that I break something so I can go 5.29 gears and add a front locker. So far all I've got is one snapped front axle. It's sad when a supercharger with supporting mods, 35's and 4.56 gearing isn't good enough. But it does say something about vehicle use.
  11. Dec 6, 2018 at 5:38 AM
    #71
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I'm getting ready to jump up from 33s, so might as well go straight to 40s and get ahead of the power curve...
  12. Dec 6, 2018 at 8:13 AM
    #72
    desertjunkie760
    Shane
    Check My Sig.
    :lalala:
  13. Dec 6, 2018 at 8:25 AM
    #73
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    lol Jeep Gladiator
  14. Dec 6, 2018 at 8:30 AM
    #74
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Hey, That thing is going to have 40" tires strait from the factory.
  15. Aug 18, 2019 at 2:46 PM
    #75
    desertjunkie760
    Shane
    Check My Sig.
    So, a little update on the direction I'm leaning towards. I damaged my RTT on a trail run in the desert and picked up a ground tent for the meantime. Figured it was a good opportunity to try different sleeping platforms out. With the removal of the tent, I now have more vertical room in the bed of the truck.
    I'm planning on building a chase rack. Link to SDHQs version below but I have a handful of changes in mind that I want for my build and there's no way I'd spend $1200 on one of these. First being I don't need two spare tires sooooo that'll be changed. After many different options discussed, I got to drive a truck with a chase rack for a week and grew to like it. I can build the rack to have a secure home for all of the necessary equipment that I take on trips while keeping the weight above the axle and closer to the cab. I'll keep the spare tire on the passenger side as well to keep the driver's view open. That's just a pet peeve of mine and would prefer to not obstruct it if possible.
    https://sdhqoffroad.com/collections...nt-toyota-tacoma-sdhq-built-in-bed-chase-rack
    eccracer104 and buyobuyo like this.
  16. Aug 18, 2019 at 3:10 PM
    #76
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Spare tire on driver side*
  17. Aug 18, 2019 at 3:12 PM
    #77
    desertjunkie760
    Shane
    Check My Sig.
    Nope, passenger. Unless you have a good reason to have it on the drivers. The truck I drove has two tires in it and the drivers side tire obstructs your view.
  18. Aug 18, 2019 at 5:11 PM
    #78
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I think it may be minimal difference since your wheel wells push the tire closer to center than fully fished to the driver or passenger side, unlike how I have it in my truck. It’s right behind me so it doesn’t effect my mirrors or looking over my shoulder.
  19. Aug 18, 2019 at 5:29 PM
    #79
    desertjunkie760
    Shane
    Check My Sig.
    I mean these will all be parts of the test fitment and mock up. My initial though was that the wheel well would push the tire into the dirver's side view like you mentioned but maybe it won't. Good thing I have a spare tire for mock up. I've not driven your truck and forgot that's how yours is setup. I do know that the truck I drove this week had this exact issue and it was a full size.
  20. Aug 18, 2019 at 8:34 PM
    #80
    tetten
    Andy
    Socal
    I'm still thinking about how to deal with this on my 2019. The most elegant solution I've come across is still SCS Vin's custom rear crossmember and spare holder. I'm wondering if it would be possible to add a custom cross member and keep the spare under the bed, just move it back as far as possible to clear the pumpkin at full stuff. I don't know if it's possible, but something I'm going to look into.
