I want to hardwire my front 6x9's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Nov 23, 2013.
  1. Nov 23, 2013 at 3:59 PM
    ajw1986
    ajw1986 [OP] Well-Known Member
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Who knows which wire is positive and which one is negative on the clip that goes into the factory speaker? Also what exact type of wire should I be connecting to extend the lines? I know nothing about car audio. I want to hardwire my new 6x9's with the custom brackets I made. Can I use regular butt connectors and spade connectors for the installation?
  2. Nov 23, 2013 at 9:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    For a 2006 Double cab:
    Positive Left door - Pink
    Negative Left Door - Violet (purple)
    Positive Right door - Light Green
    Negative Right Door - Lavender (blue)
  3. Nov 23, 2013 at 9:07 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    http://www.tacomaworld.com/forum/audio-video/301961-6x9-speaker-install-cheap.html
    If u have the stock separate tweeters and dont want to run them, the signal needs to be intercepted because toyota has the circuit running to the tweeter then down to the larger driver.
    Make sure u have enough room between the surround and the plastic speaker grill integrated into the door panel.
    I had to massage things out when I did install, but it worked.
  4. Nov 24, 2013 at 7:41 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Just buy a spool of 18 gauge speaker wire at Walmart or any auto parts store to extend the factory speaker wires. One wire is a solid color and the other usually has a white stripe. I usually use the striped wire for negative(-) and solid for positive(+) when connecting to the factory wires and your 6x9s. Spade connectors at the 6x9s make the install easier but the connectors at the wire connections optional. I usually just tied them together and use electrical tape.
  5. Nov 24, 2013 at 7:48 AM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    Thanks for all the help guys! I will do this today and let you know how it went. Nice write-up justus, i have to find my dremel now, or maybe i can angle a jigsaw in there.. lol
    The adapters i made out of my old 6x9 boxes, i just cut the top out and it's the same thickness as the plastic mount. I may consider re-using the old ones though since i saw your DIY topic!
    edit: Would t-taps work for tapping into the wire or would it be better to use butt connectors?
  6. Nov 24, 2013 at 1:17 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    It was a fun lil project. U may have zero issues with ur choice. Try it first.
    I just didn't want to buy a bracket, needed a little project, and wouldn't accept "this model will not fit your vehicle".... The fact that adaptors were available for other 6x9 models just made me want to do this even more.
    All I bought were the speakers thankfully.... Everything else was in the garage.
    As for connections, the choice is yours..... I used spade connectors to the driver to keep any future disassembling simple. All other connections were soldered, heat shrinked and taped.
    I'll run new thicker wire and solder the connections to the driver later when I install my amp.
    I bought some 12 gauge "outdoor lighting wire" used to connect accent lighting along your driveway or backyard. I plan to use most of it for my house speakers, then use the rest for the trucks speakers.
    Why did I buy this wire?
    Unlike most speaker wire now days this is actually pure copper.... Almost all speaker wire out there Thats not true audiophile grade is copper coated alloys and the back of a knife or key will scrape off the copper coating to reveal a silver colored wire. Monster from what I have seen has been coated, as well as rca, acoustic research, and many other brands even tho they will say on the label proudly and in large print "pure oxygen free copper".
    Why pay the premium for false advertising
  7. Nov 24, 2013 at 5:06 PM
    ajw1986
    Andrew
    Pitt Meadows, B.C.
    06 Money Pit
    I ended up re-using the female spade connectors that were used in the old 6x9 with the wires coming off. I didn't even have to buy wire and it made the job much easier. First side took about an hour, second side took about 30 minutes. Thanks to your DIY it made it so much easier for me. Also didn't have to notch the corners for screws to go through, I just pre drilled a small hole lined up with a self tappers. My tweeters sound ass now.. lol did you replace yours or completely remove them? Do you know if the rears are a similar process to replace?
  8. Nov 24, 2013 at 6:18 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I hijacked the signal BEFORE the factory tweeters so they do not work..... Just my preference tho. I figured the 5 way 6x9 should be good enough
    Rears I actually got free adapters from crutchfield but I also have an access cab.
