I want to lift but worried about gas millage and CV joins.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chugchug, Jun 19, 2011.
  1. Jun 19, 2011 at 4:05 PM
    chugchug
    chugchug [OP] Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    I have had a pair of 884's and 1/2" spacers for my truck and was going to lift it. Then I bought a camper last month and found that it sucks a lot of fuel from 18 miles per gallon to around 11 miles per gallon. The camper weighs 3200 lbs empty and 5900 lbs gross. I still love the look of a 3" lifted Taco.
    So help me, give me some info of what I can do and should do
  2. Jun 19, 2011 at 4:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Adding a lift won't affect your gas mileage , that comes with bigger tires
  3. Jun 19, 2011 at 4:56 PM
    Reaper10
    Reaper10 Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    I added a 3 inch lift to my 2010. These fine folks are correct, the lift won't affect your gas mileage. The larger tires and rims that inevitably come after the lift will affect your gas mileage. Not nearly as bad as that camper though! I went with a 265/70/17 on a set of XD Revolvers and with the BFG TA/KO's being a good bit heavier then the rugged trails that came on the truck, I did take a minor hit in the MPG's. Definitely nothing bad enough to make me regret lifting my truck!
  4. Jun 19, 2011 at 4:59 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Well said!
  5. Jun 19, 2011 at 5:59 PM
    762x51taco
    762x51taco Well-Known Member
    As far as cv angles, stay at 3" or less and you will be ok. As far as mileage goes like everyone said just the tires will kill it. I run 285/75/16 duratracs load range E so they are heavy as hell and I lost about 3-4mpg.
  6. Jun 19, 2011 at 9:00 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I'm running lift with 265/75/16 duratracs and my mpgs are exactly the same as before the lift back when I was running BFG rugged trails.
  7. Jun 20, 2011 at 12:36 AM
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Did you compensate your calculations for the larger tire size since the speedo will be reading different?
    Anyone know how to calculate for the difference? I'd like to know too.
  8. Jun 20, 2011 at 12:46 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Who cares, your warranty will last longer if you don't. My error is usually .1m I just did a trip across the country and was blown away that I was gettin almost 19.5mpg on my BFGs! I'm usually 17.5 city.
    If you really want to calculate the error, the math is elementary... pi * diameter:) Formula for the circumference of a circle. Divide the two and you get your error. I figured out my error by driving a few miles and comparing GPS to odometer.
    My trip guage usually says I'm gettin 270 miles to the tank, but in reality i'm getting closer to 300.
  9. Jun 20, 2011 at 7:59 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Many people have reported that after bumping up to the next tire size up from stock (265/75R16 or 265/70R17) that their speedo actually evens out to be correct. Comparing my speedometer readings to my GPS shows that I'm actually travelling 2-3MPH slower than the truck's speedometer reads. So bumping up one tire size will mostly even it out to be accurate. As for calculating the differences:
    http://www.tacomaworld.com/forum/tirecalc.php
  10. Jun 20, 2011 at 8:13 AM
    Reaper10
    Brandon
    I can vouch for this too. I went up a size from the stock 16 inch to 17 inch and my speedometer is dead on according to the gps and my incredibly helpful fort worth police officer neighbor! :D
  11. Jun 20, 2011 at 12:49 PM
    ToyTaco
    ToyTaco For the Retards, Im a Female
    Kristin
    Newark, DE
    '10 TRD Sport 4x4 modified
    i put a 3" lift on mine and bigger tires and I drive a lot and I honestly didnt see a difference in my gas mileage... now if i get into it all the time yeah you can watch the gas gauge drop haha
  12. Jun 20, 2011 at 12:55 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    DON'T LIFT YOUR TRUCK!!!
    :rolleyes: Just kidding but really that happened with a 3" lift well a little more ;) but going over 3" will cause your CV boots to fail if the fins are touching. Just keep that in mind. But it's not that bad you will just have to swap out your axles every year or so.
  13. Jun 20, 2011 at 1:47 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i wouldn't worry about your cv joints, i've got over 20k miles on mine with no problem. And a lift won't hurt your gas milesage, bigger tires will
