I want to restore my 2003 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by jacwh332, Sep 12, 2021.
  1. Sep 12, 2021 at 2:58 PM
    jacwh332
    jacwh332 [OP] New Member
    Whitney
    2003 4WD Tacoma
    Hi everyone,
    I have a 2003 tacoma with about 300,000 miles on it. He has a few dents and rust on the body, and with the way things are going with the new tacomas I want to restore him and keep him healthy. Engine is going great and have kept up on all maintenance. Does anyone have any advice on where to start? How much something like this would cost - definitely needs to get the dents out, full paint job, new carpets, and detailed upholstery? I'd love to hear any advice on what this will look like. I'm in southern california for a while, so open to referrals. Thank you!
    Taco critter likes this.
  2. Sep 12, 2021 at 3:19 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Check for frame rust first.
    Change ALL FLUIDS, coolant, brake fluid, diffs, Tcase, MT.
    Now replace all hoses and belts. 6cyl has timing belt, water pump, Tstat and pulley go with belt kit.
    Decent paint job and carpet/upholstery
    Last.
    tcjacado and jacwh332[OP] like this.
  3. Sep 12, 2021 at 3:20 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Lets hope your truck has lived all it life there and your not into Surf fishing .
    Any plans on heading into places where you see winter chemicals??
    First thing to make sure is your frame is perfect !! Before doing anything else.
    Then it all depends how picky you are with body work . A full paint job and body work can get very expensive unless you can live with something like Macco if there are any still around your locations . Each location can be so very different in quality
    jacwh332[OP] likes this.
  4. Sep 12, 2021 at 3:25 PM
    pwgarcia
    pwgarcia Well-Known Member
    Pete
    2004 Toyota Tacoma 4x4 Double Cab
    Hi there. I decided to do the same thing w/ my 2004 Tacoma double cab. Vehicle prices have been too high so I decided to try to get 300k out of my 04. I have 187,000 now...
    I live in the northeast (NH)....Toyota replaced my frame several years ago under warranty. I went to a body shop and showed them the few rust spots on the body that needed repair. The bed has a bit of rust on a seam...there are paint chips on the doors...and the windshield seal needs to be fixed up and there are a bit of rust above the windshield.
    So the body guy said for them to fix those several things it would prob cost more than the vehicle is worth...but he recommended an oil undercoating to prevent any further rust (of which there is not much) on frame....and the undercoating place would oil inside door panels and quarter panels etc.....that was only $250 to slow/stop any further rust.
    Regarding the windshield, I happen to have an appointment for tomorrow to get the seal fixed up...and they said they would take care of the rust over the windshield too....that job is costing about $260 (including the new windshield since they mentioned the old windshields often break when removed).
    Regarding the rest of the bodywork...I'm gonna look on youtube and see if I can take care of that myself.
    Beyond that, I could use some seat covers, and normal maintenance.
    I'll be watching to see how you make out and perhaps use the similar advice you receive.
    Good Luck
    Pete.
  5. Sep 12, 2021 at 4:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you make it to paint and body, can't do prep yourself, don't have a 'friend' in the biz and want it done with quality product, I'll guess $5-6k
    On a 300k truck, I agree with the others. Frame, safety items, mechanical all up to snuff before considering cosmetics.
