I want to trigger on a relay with my high beams
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LightsOut, Jul 10, 2021.
  1. Jul 10, 2021 at 11:30 PM
    LightsOut
    LightsOut [OP] Member
    14 Offroad DC
    Ive exhausted my search options and going to start a thread. I want to trigger on a relay with my high beam switch (2014). where can i find a wire that would do this? my end goal is to have my LED aux lighting turn on with my OEM high beam switch. Thanks
  2. Jul 11, 2021 at 12:06 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You could tap off of terminal # 5 of the DIM Relay in the under hood fuse panel ( Red Wire W/Black Stripe ) which powers the High Beams to pick up the Coil of your Aux LED Relay.
    DIM Relay # 5 >> Fuse >> Coil of Aux LED Relay >> Ground.
    sloth671, Juisebocks and TnShooter like this.
  3. Jul 11, 2021 at 7:43 AM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    This is the way. Tap to the relay you want to power your thing.
  4. Jul 11, 2021 at 9:08 AM
    caribe makaira
    Caribbean, Puerto Rico
    Add-a-fuse to high beam fuse as trigger to added lights relay.
    Jimmyh likes this.
  5. Jul 11, 2021 at 9:19 AM
    caribe makaira
    Another option:
    For your '14, test the same #wire for high beam (-).
    @kmorgan3 could provide the T harness on C11 for a no cut tap.
    TnShooter and Jimmyh like this.
  6. Jul 11, 2021 at 5:28 PM
    LightsOut
    14 Offroad DC
    so you are using the ground side of the relay trigger it "on" then? i understand the normal operation of a standard 4 post 12v relay, but this is different than i have ever wired one.
  7. Jul 11, 2021 at 5:29 PM
    caribe makaira
    All relays on the Tacoma are ground switched...
    a few here:
    Jimmyh and TnShooter like this.
  8. Jul 11, 2021 at 5:51 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I have my lght bar triggered by my highbeams.
    Used a add a fuse in the main fuse panel on the high beam fuse.
    I opened up the wiring harness, and connected that wire to the relay. I also have the switch mounted in the cab, so I can operate the high beams without the light bar if needed, such as for a inspection or something.
    Jimmyh and Juisebocks like this.
  9. Jul 11, 2021 at 6:52 PM
    LightsOut
    14 Offroad DC
    thats exactly what i want. so you did yours like this that is in post #4 above
  10. Jul 11, 2021 at 7:04 PM
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
  11. Jul 11, 2021 at 8:10 PM
    HawkShot99
    Kingston, NY
    I used a wiring harness I bought off Amazon. It has been several yrs since I installed it, so I do not remember what pins on the relay I used, but followed the directions.
  12. Jul 12, 2021 at 3:08 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I don’t know how to create the fancy diagrams but as another idea, I used these relays for my lights:
    5 Pack 40/30 AMP 12 V DC Waterproof Relay and Harness - Heavy Duty 12 AWG Tinned Copper Wires, 5-PIN SPDT Bosch Style Automotive Relay https://www.amazon.com/dp/B074FSZWVT?_encoding=UTF8
    I can either operate the light independently or press my Hi Beam Assist button and the specific light bar button and they come on with the Hi Beam circuit
    HawkShot99 likes this.
  13. Jul 12, 2021 at 3:23 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
