I was quoted $500.00 for spark plug replacement on my 2016 Toyota TRD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dthieren, Aug 3, 2021.
  1. Aug 3, 2021 at 8:01 PM
    #101
    Sasquatchian
    Sasquatchian Well-Known Member
    I think you want to use anti-seize on the threads and dialectic grease where the coil pack grabs it. I don't know if these plugs have a screw on tip on the end where the coil pack attaches but those should be snugged up with a pair of pliers just to make sure they don't loosen up over time. The only time where I haven't used a torque wrench for plugs was on my 911 where it was literally too tight to fit one in there. The Porsche was a real bitch to do plugs on and even more difficult to put Koni's in the rear but the most difficult plug replacement I did was on a '91 Nissan 6 cyl truck, the engine where the V-6 is rotated over about 40 degrees and one of the rear plugs was completely by feel while laying across the top of the motor while jamming your left arm down between the motor and the firewall. I gave that one away to my father's gardener after he died and needed to get it smogged in order to give it away. The Tacoma looks simple by comparison.
    Tacogeorge17 likes this.
  2. Aug 4, 2021 at 12:16 AM
    #102
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    CT
    gsubioguy[QUOTED] likes this.
  3. Aug 4, 2021 at 4:03 AM
    #103
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Then you did it wrong. 3rd gen spark plugs are one difficulty notch above tire rotation.
    Mark77 likes this.
  4. Aug 4, 2021 at 6:08 AM
    #104
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Well that contributed to the collective knowledge.
    Mark77 likes this.
  5. Aug 4, 2021 at 6:32 AM
    #105
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    I havent done it yet but being that I changed 16 spark plugs (2 per cylinder) in my Ram hemi a few years ago it cant be too bad.
  6. Aug 4, 2021 at 7:00 AM
    #106
    Guinness Dave
    Guinness Dave Active Member
    Savannah
    White TRD OR DCLB
    How in the world do you need new plugs at 5 years?
  7. Aug 4, 2021 at 7:29 AM
    #107
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Per the Toyota maint book, plugs are due at 60k so he's probably there or close to. Others have gone beyond that and were fine so "after 60k - whenever you want" seems to be the real world interval.
  8. Aug 4, 2021 at 8:15 AM
    #108
    dhillr
    dhillr Well-Known Member
    Dave
    2019 TRD Off Road
    Nice! Appreciate you taking the time to write this up. Will save a lot of us some frustration down the line.
  9. Aug 4, 2021 at 8:27 AM
    #109
    TX BAJA1
    TX BAJA1 Well-Known Member
    2021 LUNAR ROCK TRD PRO
    Alldata labor time for this job is 3.0 hours
    shark56[QUOTED] and ToYoda4x4 like this.
  10. Aug 4, 2021 at 8:34 AM
    #110
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    I work at a large Toyota dealer. 85% of our techs are flat rate.
    ToYoda4x4 and Lt. Dangle like this.
  11. Aug 4, 2021 at 8:34 AM
    #111
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Welcome to world of flat rate lmao.
    just cause a job takes 15 minutes doesnt mean your getting charged for 15 minutes of work. i dont know why everyone is so surprised by this quote. Go look up the fsm for changing spark plugs.
    hiPSI likes this.
  12. Aug 4, 2021 at 8:37 AM
    #112
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is the funny part. It looks like the plenum was designed with just enough room to get all three coil packs out. That doesn't seem to be an accident compared to other vehicles that I have had with difficult plugs. I 100% do not understand why the Service Manual goes bonkers with the procedure.
    Of course, a few folks have posted in other threads that they prefer pulling the plenum to swap plugs.
  13. Aug 4, 2021 at 10:03 AM
    #113
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Not sure why I got quoted, I clearly understand how flat rate works.
  14. Aug 4, 2021 at 10:51 AM
    #114
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    If you aint replacing. Just check how tight they are. They usually get loose by 60k
  15. Aug 4, 2021 at 11:33 AM
    #115
    Sungod
    Sungod Well-Known Member
    St Augustine
    I don't know what dealership you work at, but outside of the lube dopes everyone is paid flat rate. Now they are paid hourly, but they are paid flat rate hourly. If a job is a 3 hour job as this one is, they are paid 3 hours regardless of how long it takes. That is how they make money. I couldn't imagine the productivity of a shop were all the techs were paid an hourly rate like the guy working fries at McDonalds.
    A good friend of mine is an alignment tech at a high volume Toyota dealer. He regularly books 100+ hours a week. He is a 1099 worker and not a w2. He is paid 40% of the shop hourly rate which is around $125 an hour. You can do the math, but the guy is bringing in over $200k a year. However, out of that $200k, he has to pay his own taxes, medical, etc. He is still doing quite well.
    hiPSI likes this.
  16. Aug 4, 2021 at 12:58 PM
    #116
    Guinness Dave
    Savannah
    White TRD OR DCLB
    It's not apples to apples, but, I swapped plugs on my 2009, 2.7L Taco at 120k miles in 2019. Thinking I'd get a little better pep and mileage. The stock plugs looked almost brand new...
    tonered likes this.
  17. Aug 4, 2021 at 1:03 PM
    #117
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Back in the day, we use to swap plugs out on a fairly regular basis. But plugs cost a dollar each back then and they damn near changed themselves on most engines. :)
    tonered and Mark77 like this.
  18. Aug 4, 2021 at 1:03 PM
    #118
    golfindia
    Yes.
    pickup truck
    Data point:
    I drove on original spark plugs in my 2004 2.4l extra cab until it threw a CEL. Gap was almost 1/4".
    I was at 168k miles.
    tonered likes this.
  19. Aug 4, 2021 at 1:08 PM
    #119
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Never makes sense to go to dealer other than warranty or recall work. A qualified shop, yes but never a dealer. The monkeys they have working in there are no better qualified than any other monkey.
    Mark77 likes this.
  20. Aug 4, 2021 at 1:10 PM
    #120
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's hilarious.
    :cheers:
