I was wrong....10 ply vs 6ply. The whole truth...but the plot thickens on page 5....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Oct 12, 2017.
  1. Oct 13, 2017 at 9:31 AM
    #81
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Nah, I ran them around 35 psi
  2. Oct 13, 2017 at 9:31 AM
    #82
    nevadabugle
    Elko, NV
    I
    If anything too much pressure.
  3. Oct 13, 2017 at 9:31 AM
    #83
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Maybe not airing down enough, not too much. You'd have to pretty much run them flat to be aired down too much.
    BTW, 235/85R16 pizza cutters FTW!
    DubfromGA, DavesTaco68, rlx02 and 2 others like this.
  4. Oct 13, 2017 at 9:51 AM
    #84
    erok81
    erok81 Well-Known Member
    Imposter
    I think it's just those tires. It's pretty much impossible to get ply specs over th internet. However I did just read an article that even the E rated duratracs have 2 ply sidewalls (I cannot verify the article though as I don't have those tires).
  5. Oct 13, 2017 at 10:12 AM
    #85
    nevadabugle
    Elko, NV
    That is true. I looked into them in a 235/85 E. And they still had 2 ply sidewalls.
    rlx02 likes this.
  6. Oct 13, 2017 at 10:16 AM
    #86
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Well I'll be damned.
    erok81[QUOTED] likes this.
  7. Oct 13, 2017 at 10:25 AM
    #87
    erok81
    Imposter
    I don't think I could have afforded it being younger.
    How old does one usually need to be for a vehicle like mine?
    If it's even better prior to this truck I had a bagged, wide body, turbo'd, BRZ. :)
    Danactive and rlx02[QUOTED] like this.
  8. Oct 13, 2017 at 10:37 AM
    #88
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I guess I always see younger dudes rocking LT trucks with glass fenders. Guys in their 20's who don't mind road noise or jarring rides.
    That's why I'm here trying to make sure that the idea of higher load rating on a tire doesn't necessarily mean better puncture protection. I'd like to run a C load since I don't have any extra weight in my bed or plate bumper. Currently running E's and they're stiff and loud as hell. So far everything points to no, load range does not mean more protection.
    erok81[QUOTED] and DaveInDenver like this.
  9. Oct 13, 2017 at 10:49 AM
    #89
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I haven't been able to correlate load range to higher puncture resistance either, but construction seems to be. I've had success with lots of different 3-ply sidewall BFGs, the old KO and KM, current KO2 in various sizes and C, D, and E load ranges.
    Being a load range E simply means it can safely hold 80 psi nominal pressure, which can obviously be achieved with 2 plies and I assume thicker rubber. But that doesn't seem to help resistance to punctures that just cut through rubber.
    The numbers of plies and the lay-up of them crossing to support the rubber better is my theory as to why I and the guys in my 4wd club have better luck with BFG than Duratrac tires.
  10. Oct 13, 2017 at 10:59 AM
    #90
    nevadabugle
    Elko, NV
    Changing title to the "The plot thickens page 5..."
    Hawco636 and erok81 like this.
  11. Oct 13, 2017 at 11:01 AM
    #91
    nevadabugle
    Elko, NV
    Title changed...lets keep the dialogue going. The good news is, my new ST Maxxs have more plys and what appears to be a better lay up of said plys.
    erok81 likes this.
  12. Oct 13, 2017 at 11:07 AM
    #92
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    This correct.
    Just because you have more Plies doesn't mean that you're going to have less punctures it is less subjectable to punctures going all the way through the tire and causing a leak because of all the Plies but that doesn't mean that the rubber! is harder! and it's not going to crack, splinter or get punctured as any other load rating.
    If anything look at the passenger tires their mileages are rated higher than the LT and assumingly that would mean that the rubber is harder.
    Joe23 likes this.
  13. Oct 13, 2017 at 11:13 AM
    #93
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I would also mention that when you see tires fail on the trail that aren't obvious punctures with a root sticking out they are usually bubbles the carcass. My thought is that is also due to number of and orientation of plies. When we air down, or I guess even if we don't, off road the tires are asked to distort around obstacles that are often odd shaped and can be quite sharp, which I think causes the weave to fatigue and break strands that eventually leads to a failure.
  14. Oct 13, 2017 at 12:04 PM
    #94
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I read pg 1 then skipped to pg 5... but I'll throw in my 0.02.
    I have C rated winter tires. I thought "oh it's fine because they only see light duty, no gnarly rocks or anything". Average 2 flats per winter, every flat has been slices in the sidewalls from going down gravel roads (even 1 on a good highway). Road hazard warranty is boss.
    I have E rated summer tires. Bounce them off of all kinds of crappy sharp rocks and literally never had a flat.
    The difference could have nothing to do with load ratings though... the E rated summers are Micky Thompson ATZ P3s which are probably designed with more punishing conditions in mind.
    nevadabugle[OP] likes this.
  15. Oct 13, 2017 at 12:09 PM
    #95
    nevadabugle
    Elko, NV
    So let's think about this...how does someone purchase the most puncture resistant tire possible?
    If plys mean nothing for puncture resistance and load rating means nothing for puncture resistance, how does someone choose a tire that will perform for their given abuse level?
    I am even now questioning if D cups truly are better than A cups?
  16. Oct 13, 2017 at 12:27 PM
    #96
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Another perspective:
    Ds are made for comfort, As are made for performance.
  17. Oct 13, 2017 at 4:20 PM
    #97
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    If you want puncture resistant... Then you get mt/R's with Kevlar those things are bulletproof
  18. Oct 13, 2017 at 4:36 PM
    #98
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I hear Goodyear Wrangler All-terrain Adventure with Kevlar is super puncture resistant.
    In fact, I hear they're so puncture resistant, Toyota uses them exclusively for their top-of-the line Tacoma TRD Pro model.
  19. Oct 13, 2017 at 6:08 PM
    #99
    nevadabugle
    Elko, NV
    Exactly...although those shitty stock tires are the same one that the banned Smitty praised so highly. How it was that he hated everything about his truck except the worthless tires that came on it makes no sense to me...
  20. Oct 13, 2017 at 6:35 PM
    #100
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    I wondered where he's been! Figured the tires finally blew out somewhere far far away.
