I went ballistic------almost..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WCJR, Oct 6, 2009.
HAVE YOU EVER BEEN REFUSED NEW FRONT TIRES ON YOUR 4 WHEEL DRIVE UNLESS YOU DID ALL 4
Poll closed Nov 5, 2009.
  1. YES
    7.3%
  2. NO
    43.6%
  3. IS SOMEONE NUTS
    49.1%
  1. Oct 6, 2009 at 7:14 PM
    WCJR
    WCJR [OP] Well-Known Member
    W
    This does not directly relate to my 09 tacoma but it could.has anyone out there ever heard this one....
    Today i took my other truck in for 2 front tires. I paid for them went out for a soda and after 30 minutes i was paged. Went back to service area and saw that right front tire was off and new one next to fender.
    This is an f 350 with dual rear wheels and it is 4 wheel drive.
    So here it is, they refused to install the new fronts unless i bought 6 tires, new all around.
    Reason, its a 4 wheel drive and they have to do all 4 or 6. Corporate policy.
    They could not show me a copy of the policy or explain the logic.
    So has anyone else out there in tacoma land ever been refused front tires on their 4 wheel drive unless they did all 4 wheels.
    Would appreciate your input....
  2. Oct 6, 2009 at 7:17 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    im calling BS to that.. ive never heard of that before.. sounds like they wanted to make a few more bucks
  3. Oct 6, 2009 at 7:18 PM
    WCJR
    W
    That statement was given by employees and a manager. I will post the store NAME later.
    Thanks
  4. Oct 6, 2009 at 7:19 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Can't say that we have had that happen either...
  5. Oct 6, 2009 at 7:19 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Always bought sets of four...but have never heard this before?
  6. Oct 6, 2009 at 7:20 PM
    THE TECHNICIAN
    THE TECHNICIAN Well-Known Member
    If the overall diameter of the tires is severelly different per axle then it may affect the way the ABS acts or engages.
  7. Oct 6, 2009 at 7:20 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    Never had it happen to me since I usually need all four however I have heard of that policy before. The claim it's to protect them for liability reasons since the two that were replaced will have better tread and subsequently more grip than the two not replaced. On 4wd they don't want you to be in 4wd and have a situation with different grip between the front and rear which would lead to an accident and subsequenly they would be sued.
    If you've ever had just two wheels replaced on an 2WD vehicle you'll notice that they will almost always put them on the drive wheels no matter which two you asked to be replaced. Same reason though.. drive wheels need the grip.
  8. Oct 6, 2009 at 7:21 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    My best friend owns a tire shop this is bullshit! Not true at all !
  9. Oct 6, 2009 at 7:22 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    It sounds like you might have been to wal-mart, I ordered a set of 285s from them a few years ago and they wouldnt install them on the truck because they werent the exact factory size.
  10. Oct 6, 2009 at 7:26 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    one guess on where this was....walmart? if so then yes i have heard of obsurd things like this come from them. they are full of shit and just tell them to put your tires on and take it to a regular tire shop. they did this to me with a boat trailer. they refused to put a reglular vehicle tire on it because it was not specifically a "trailor tire". it was just a regular 6 ply tire like the ones that were already on the trailer. took it back home put it up on jack stands and took the wheels back to the same person that told me all this and not another word. the kind of people that work there are not "technicians". they have very minimal knowlege, or skill, of the things they are doing.
    another story about them and the main reason i dont take any vehicle i own to them. buddy of mine took his truck up to them to get an oil change. just a 1/2 chevy 4x4. seems pretty routine and simple right? i guess not. they did the oil change as he browsed the shelves near by. 20 minutes goes by he gets paged, pays for it and goes on. couple mile down the road the motor seizes and overheats. we got it towed home and went to check it out and its bone dry! not a drop of oil in it!
  11. Oct 6, 2009 at 7:27 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Oregon law requires studded tires sold as 4 due to front whl drives spinning around when they bought just 2. I'm thinking it could be a liability issue so they implement it, and oh btw now they get more $$ per sale.
  12. Oct 6, 2009 at 7:27 PM
    wheresthericego
    wheresthericego Active Member
    Raleigh NC
    97 Tacoma, 94 SR5
    Sounds like some horse shit to me. I would make them refund me 100% and drive to the next tire shop. Tires shops are more common than used car lots and the markup is about the same. There is a huge profit margin in tires so always research between different stores vs. online you will be surprised.
  13. Oct 6, 2009 at 7:30 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    well, its not so much coperate..Its a well known fact that if you buy 2 tires, on a 4x4 or AWD, it can screw up the differential if they are not within i think 2MM of the rest of the tire tread. AWD and 4x4's are funny like that
  14. Oct 6, 2009 at 7:35 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    2MM is so small that theat cannot be true. at least not to a diff. maybe the half shafts in the front but not the rear. on my honda s2000 its rear drive and has half shafts in the rear and this is possible but its not a 2MM difference by far. also AWD is totally different than 4wd so the same things should not apply to 4wd. 4wd is selectable and awd is constant. the diffs in the awd systems are so different than in 4wd. thats the reason you arent supposed to put your truck in 4wd while on pavement.
  15. Oct 6, 2009 at 7:56 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    That should really only apply to All Wheel Drive vehicles. Not 4WD
    AWD vehicles have a viscous center diff. The different rolling diameter between front and rear wheels could mess the center diff up.
  16. Oct 6, 2009 at 9:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    No...Shit no man...I beleive you'd get your ass kicked saying somethin' like that man (Office Space) :laugh:
  17. Oct 6, 2009 at 9:48 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Why go ballistic? Just go elsewhere.
  18. Oct 6, 2009 at 9:49 PM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    my guess would be Costco
    In British Columbia, it is a law that all 4 tires must be the same brand/model/size on a 4x4. A 2x4 has the same restrictions only on a per axle basis
  19. Oct 6, 2009 at 10:48 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    A few shops have tried this to me (discount tire for one) with my G35. They even tried to refuse me being alowed to drive away. I told them let me ask Chandler PD what they say... they gave me the keys. Another time they said I needed 4. I said replace the rear 2 I can still run the fronts longer. They refused... I told them I'd do another shop willing to do buisness. Long story short, they gave me $30 off a tire and one free one (paid 3) and I got all 4. I was ok with that... :D
  20. Oct 6, 2009 at 11:24 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    easy solution, take your wheels off yourself at home or wherever, and have the tires replaced off the vehicle at the shop. since they are not installing the wheels on your truck, they are no longer liable.
