I went ballistic------almost..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WCJR, Oct 6, 2009.
HAVE YOU EVER BEEN REFUSED NEW FRONT TIRES ON YOUR 4 WHEEL DRIVE UNLESS YOU DID ALL 4
Poll closed Nov 5, 2009.
  1. YES
    7.3%
  2. NO
    43.6%
  3. IS SOMEONE NUTS
    49.1%
  1. Oct 7, 2009 at 4:42 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    That's Bullshit. Go elsewhere. I've never heard of that.
  2. Oct 7, 2009 at 4:58 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Did your friends truck NOT have an oil gauge or a functioning idiot light?
  3. Oct 7, 2009 at 5:39 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    Ok here we go and no one please take this the wrong way.
    Yes on a 4wd and AWD all 4 tires must be the same.
    Why rolling resistance tread needs to be the same on all 4 tires
    and can not be more them 4/32 of tread from tire to tire.
    Look at this way some one does do the two tires for you
    and you will always find someone that will but lets says
    after its done something goes wrong with the trans or
    the diff you take it to a trans shop or the DEALER.
    He says look at this all 4 tires are NOT the same.
    SOOO now you go back to the tire guy and want him
    to pay for a new trans bc he should have know better.
    Beleve me guys i see day after day.
    We would love to sell you just two tires its better them selling
    none.:D It should say this right in your manual
    It does in the ones for Audis and BMW :D
  4. Oct 7, 2009 at 8:09 AM
    ligero18
    ligero18 Well-Known Member
    Ohio
    They probably got sued at some point. If it's their policy they should still have at least a waiver releasing them from liability. I just bought tires from wal-mart and in fact they had a sign with a picture that showed if only 2 tires are replaced they need to be put on the drive wheels. If this is Wal-mart it must not be company wide policy.
  5. Oct 7, 2009 at 8:13 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    that's rediculous. call up the 1800 number for that company and complain.
  6. Oct 7, 2009 at 10:12 AM
    S-M-R-T
    S-M-R-T Well-Known Member
    The issue is with the overall circumference of the tires which if I remember correctly have to be within something like 2% of each other front/rear or you will be have drivetrain binding issues when 4x4 is used on pavement because the axles will want to spin at different speeds and there is no slippage in the drivetrain to accomodate this. If you only engage 4wd on lower traction areas (mud, etc.) then this becomes less of an issue because the tires are able to spin more freely. The same issue is common on 4x4s built with mixed axle brands where the gears sets are not the exact ratio (ie. 4.11 gears in the front and 4.10 in the rear.) where the same sized tire will spin at slightly different speeds. Personally I think that people who use 4x4 as a crutch rather then a tool deserve to grenade their drivetrain.
    How does this apply to duallies and larger trucks that are still 4x4? Duallies commonly run a different model steering tire and driving tire and they are not required to be the same, even on a 4x4.
  7. Oct 7, 2009 at 10:18 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I use to buy 2 tires at a time with my Expedition all the time. How can the person there tell you how much money you want to spend that day.
  8. Oct 7, 2009 at 11:53 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I drive a Suzuki SX4 AWd car for work and regulary get tires put on. Never once did the garage try to put on all 4 new tires. Many times they just installed one new tire.
  9. Oct 7, 2009 at 12:55 PM
    Richman21
    Richman21 I think therefore I'm a Democrat
    Jeff
    Albuquerque, NM
    09 DC Sport PreRunner
    Hardwire radar detector. Tube steps.
    That's what I think. Costco has weird rules.
  10. Oct 7, 2009 at 1:03 PM
    Jmartin89
    Jmartin89 Well-Known Member
    James
    TEXAS
    09 tacoma TRD off road
    265/75/16 buckshot mudders, 3" lift OME 886 coils, LR UCA's, TRD cold air intake, AllPro rear bumper, rock sliders, and front bumper
    screw that its a bunch of BS i would have went insane if they had told me that
  11. Oct 7, 2009 at 4:17 PM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    I worked at Discount Tire for a little over a year.. and never heard of someone having to get all 4 tires done.. unless the back two were "unsafe" to drive on.. and then its kinda like we cant let you because we can be held reliable for not replacing tires with belts showing.. etc
  12. Oct 7, 2009 at 4:38 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    It's definitely a liability issue... I worked as a tech. at Les Schwab for awhile and they had a policy like this (or similar): If a customer came in to buy new tires and did not want to replace all four, we had to check the wear specs. on all the tires. If the customer wanted to leave a tire on the vehicle that was past the max wear, it was considered a liability for the company so we would do our best to talk them into replacing all for. If a customer only bought tires of their choice and drove off with a tire that was unsafe and was involved in an accident, they could pin it on the company. IDK about dually or the 4x4 situation. A prior post kinda makes sense about the abs system though. ;)
    Now, if the customer insisted on doing it their way I've seen a number of times where they would just go ahead and give them what they wanted, but inform them of any safety issue.
  13. Oct 7, 2009 at 4:57 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    I work at a BMW/MINI dealership have never heard of this I see the BMW tech change out 2 tires all day long on AWD cars....only policy we have is is not patching Run Flat Tires.
  14. Oct 7, 2009 at 7:43 PM
    baildavc
    baildavc TREADING LIGHTLY!
    David
    Jasper, AL
    08 4x4 white DC OR
    3 inch lift, 33's, bull bar, debadged, windows tinted, direct wired power inverter, blacked out front emblem,
    I'm calling SHENANIGANS!
  15. Oct 7, 2009 at 7:52 PM
    #35
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    sorry, don't know. B.C. has some weird laws
  16. Oct 7, 2009 at 8:04 PM
    #36
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    OK, what if you only need one tire due to a blow out? The other three have, say 25k on them. Will they force you to buy all or even 2?
    Also, they sold you the tires, why did they not inform you of that policy at the time of purchase?
    I'll call it BS.
    Yuma Taco,
  17. Oct 7, 2009 at 8:22 PM
    #37
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    I've heard of the differential issue before on 4X4's, can't say whether I believe it or not. But when I've had 2 tires replaced on my work van, they put the new ones on the front, not the drive wheels. Their reasoning was to prevent hydroplaning.
  18. Oct 8, 2009 at 2:55 AM
    #38
    David Tarantino
    N.J.
    08 tacoma
    and or going into a turn that is right:D
  19. Oct 8, 2009 at 3:26 AM
    #39
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Oh no! :eek: Not that again. How does this keep happening? Damn shenaniganuristas! :D
  20. Oct 8, 2009 at 3:08 PM
    #40
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I'm just going to throw the bullshit flag!
    If this was true, how come cars come with a small donut tire ?????
    as for 4x4s, if there the same size tire, there fine.
    This is just how tire sales make more money - period.
