i will control the brakes thank you!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toyotabladerunner2022, Nov 30, 2023.
  1. Nov 30, 2023 at 9:31 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    With the number of onboard systems that now need to talk to ABS, I would be surprised if it was as simple as pulling a fuse.
    SH10151, Squirt, Chew and 1 other person like this.
  2. Nov 30, 2023 at 9:42 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    If it’s an Off Road model pulling the fuse disables the Electronic Brake Booster and you have like 10% braking.
    shakerhood, Lt. Dangle and YF_Ryan like this.
  3. Nov 30, 2023 at 9:58 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    ABS has nothing to do with stopping distance, it’s designed to allow you to steer around what you are trying to avoid.
    Some instances your stopping will be longer but you “have control “.
    If you cannot stop your going too fast for the conditions.
  4. Nov 30, 2023 at 10:18 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    It's ancient boomer logic that ABS is worse in the snow and ice. This has been disproven many times.
    But like, you do you, I guess. I imagine you can just pull the ABS sensors. What's the worst that could happen?
  5. Nov 30, 2023 at 11:00 AM
    kaljam
    kaljam Well-Known Member
    Bill
    New Hampshire
    2023 TRD Sport wind chill pearl
    Sorry Rusty66 - you are incorrect - ABS most certainly DOES have something to do with stopping distance, been in too many situations where I could NOT stop the truck (and not speeding).
    My ABS fuse gets pulled every winter. I am sure ABS is good for something - I just haven't found what that is yet.
    Jojee117 and BamBeds like this.
  6. Nov 30, 2023 at 11:07 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Light show!!
    I really don't mean to be disrespectful when I say this; but some should just keep buying old timey vehicles, rather than expecting new to be old. Things change, some people don't,,,, and again, that's totally fine, just the way it is.
  7. Nov 30, 2023 at 11:14 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Pull the fuse and try it out? :notsure: You might lose VSC or you might get constant annoying beeping. Also make sure you can switch between 2hi and 4hi with the fuse pulled.
    Turd gens have a different ABS calibration in 4hi, so disabling may not be as necessary as legacy systems.
    Also need to be mindful your truck is 1000 lbs heavier than your '99 4Runner, so drive it like a heavy truck and aggressively downshift to use engine braking when you can.
  8. Nov 30, 2023 at 11:35 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    This reminds me of those tech bros who show up for a track day and go around to the other drivers asking how to disable all the “bullshit nanny” safety systems on their brand new 911 not realizing that you need those things from getting yourself killed unless you are a ridiculously professional driver.
    Which they are not.
  9. Nov 30, 2023 at 11:36 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Can someone share some details on the bolded text above? This is interesting. I do not recall reading this in the manual (I guess that does not mean it is not there...!). But it would be helpful to have insight on how this is intended to work.
    I know (at least a portion) of what the OP is talking about. I have experienced at low speeds, that the ABS insists on backing-up on braking in order to keep tires continuously rolling until a full stop... It basically overrides your mashing on the pedal. It just keeps rolling along...
    - I believe this is how the OP missed turn-offs.
    I am aware of this now - but I would still not disable the ABS. It will certainly save you when getting sideways unintentionally on the road... (Via a complimentary system - not directly.).
    I do recall that my first ever ABS vehicle's ABS would only work above a certain speed. (like 10mph? - Per the manual). < THis seems to make sense to me as a parameter for ABS.
    BamBeds likes this.
  10. Nov 30, 2023 at 11:38 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    That would be interesting to know. I do know at least some other vehicles have similar changes. Ford Raptors for one, have an offroad mode, that backs the ABS off to build a pile of sand in front of the tire, before then allowing the ABS to work. It's explained pretty well online, and in the manual i believe. My sister's came with a laminated card that showed what all the modes did.
  11. Nov 30, 2023 at 11:39 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There are times and places where you would be better off without ABS. But most of those are off road. On pavement you are better off with them 90+ % of the time.
    I could live with a switch where they could be turned off and on easily from inside the cab. But pulling the fuse disables them too much.
    musicisevil, SH10151 and YF_Ryan like this.
  12. Nov 30, 2023 at 11:44 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I could see a situation either with studded tires on ice or very specialized ice driving tires with extensive siping, where some lock up would be helpful to allow the tires to dig in to the ice layer, but this is an extreme example. And you would still need integration with the vehicle stability system to ensure that you are not going sideways.
    musicisevil likes this.
  13. Nov 30, 2023 at 11:46 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    The 2nd gen guys used to bitch all the time about ABS nearly killing them on ice. Having abs/trac disabled was a common trend for at least a subset of winter folk. I assume that’s what is being referred to. I could be wrong.
    33yrsoftoys and BamBeds like this.
  14. Nov 30, 2023 at 12:00 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    When the 5th gen 4Runner (and mid-cycle refreshed FJ Cruiser) appeared in 2010, one of the advertised enhancements was off-road ABS calibration (which just means allowing greater degree of lockup before intervening). 3rd gen Tacomas are expected to have it as well. You won't see it in the owner's manual because it works behind the scenes, in similar fashion to the "RSCA disable" function no longer requiring driver action on 3rd gens.
    Lt. Dangle and SH10151 like this.
  15. Nov 30, 2023 at 12:14 PM
    #35
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    You're right about this, I was one of those guys. My 2nd gen would literally give up braking on one side of the truck, which could stop it in a foot or two, on dry pavement at 5mph trying to stop for a stop sign or red light, because the other side was on ice. Literally coast right through the intersection in slow motion. I'm really happy my 3rd gen doesn't do this.
  16. Nov 30, 2023 at 12:25 PM
    #36
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    Lol. That was me in my old subaru. ABS, all wheel drive, traction control, winter snow tires on a snow cover parking lot with ice underneath doing 10mph slowly spinning in circles down a hill all the lights flashing on the dash. couldn't do a thing until gravity gave up. Landed right next to another car without a scratch. There's nothing like that feeling just hold on tight and hope the tires bite into something.
  17. Nov 30, 2023 at 5:39 PM
    #37
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i would encourage you to try the "long press" on the tcs system for at least part of the winter. i used to also disable/not-maintain the ABS systems in my older vehicles because the single-channel ABS systems of old were horrifically intrusive, unpredictable at the absolute worst times, and generally as useful as techno music in church.
    but now with multi-channel ABS systems, they react much faster, less violently, and also only where needed, meaning that backing off the brakes to regain control will have a much more consistent effect, the same as you'd be used to doing with non-ABS-equipped/disabled vehicles.
    i've got a lot of snow miles on my '14 brz, and my '18 tacoma, and have found the long-press for the TCS to be more than adequate for most situations.
    'outperform' is a misnomer.
    ABS does not immediately make a vehicle handle better.
    ABS inherently trades stopping distance for steering control. this is good, and bad. but ABS is also a 'spontaneously reactive' system, meaning that it cannot react to a situation until the vehicle has already started sliding, and there is also no warning to this.
    there's really 2 schools of thought here-- firstly, the best driving technique is to drive without creating a situation where wheel slippage can occur.
    you're correct, no human can ever pulse the brakes as fast as a computer. but at the same time, no computer can properly read and prepare to work through a situation as well as a human either.
    the second school of thought considers that there's also helpful wheel slippage.
    i've gone out of my way to own rwd/4x4 vehicles specifically because of the control such a drive layout offers in the way of control-- i can independently control the front and rear axles by modulating the brake or the gas. it is entirely possible to control a vehicle safely while sliding with the gas/brake, something that goes entirely against the programming of any ABS system. love it or hate it, entire vehicle sports associations are designed around this principle.
    ABS is specifically designed as a workaround to the human condition of "pedal mashers" "I WANT CAR STOP, CAR NO STOP, I MASH BRAKE, STOP CAR STOP!"
    that doesn't mean that ABS is bad, but implementation, reliance, or otherwise omnipotent-expectations out of the system is setting up one's self for failure.
    all that said, proper tire selection and maintenance, as well as having a clear understanding of one's own skill limitations will play a much more significant role in any safety mitigation strategy, far more than any vehicle system ever can.
  18. Nov 30, 2023 at 6:01 PM
    #38
    81shark
    81shark Well-Known Member
    I agree with op. Not a fan of abs. Sometimes I want to lock em up
    Toy_Runner likes this.
  19. Nov 30, 2023 at 6:07 PM
    #39
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    I don’t know. ABS kicked in on some ice and had me almost my pants! But I am a desert driver and had no business driving during a whiteout.
  20. Nov 30, 2023 at 7:09 PM
    #40
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    It isn’t even Friday yet
    :popcorn::popcorn:
    Tiedie likes this.
