I wish these had more power! Any options?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Synnik, Mar 14, 2017.
  1. Mar 16, 2017 at 7:50 AM
    #81
    Ledfoot 26
    Ledfoot 26 Well-Known Member
    16 TRD OR 4x4 Barcelona Red
    I owned a 2007 Tundra and a 2015 Tundra, I get 6 miles more to the gallon in the Tacoma, Thats 120 miles more on a tank of gas!! I think there's something seriously wrong with you're truck if you're getting almost the same as a Tundra....
    ebbs15 likes this.
  2. Mar 16, 2017 at 8:14 AM
    #82
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    It goes to show that there are a lot of factors in high performance besides HP. It's the low end torque of the 2nd gen that helps it. It's tough to replace displacement with technology unless maybe it's being replaced by an electric motor.
  3. Mar 16, 2017 at 8:17 AM
    #83
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Not to mention the new ZR2. Pretty cool, potentially the first real competition Tacoma had ever seen.
  4. Mar 16, 2017 at 8:17 AM
    #84
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    How about sticking a 572 cu in Big Block Chevrolet under the hood? 9.3Liters
    Skeou and Haany4x4 like this.
  5. Mar 16, 2017 at 8:19 AM
    #85
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Pass everything but a gas station...
  6. Mar 16, 2017 at 8:20 AM
    #86
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Haha that could be made to work but where would you put the gas tank?
  7. Mar 16, 2017 at 8:31 AM
    #87
    Woodrow F Call
    Colorful Colorado
    This thread is about moar powah!!!!!
    Maybe stick a 14-71 on top?
  8. Mar 16, 2017 at 8:43 AM
    #88
    gpb
    Atlanta
    Mount a couple of JATO units in the bed.
    Skeou and Woodrow F Call[QUOTED] like this.
  9. Mar 16, 2017 at 8:45 AM
    #89
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    But there is no reason they could not have made a 4 cylinder turbo or some thing similar. Fuel efficient and fun.
  10. Mar 16, 2017 at 8:47 AM
    #90
    sbond007
    sbond007 Well-Known Member
    STEVE!
    PHX, AZ
    '12, OR, DCSB.
    NOS sticker + 100hp
    Funny that you mention this. I test drove the new Limited Tacoma, the 3.5L felt like a moped when I punched it. So I decided on a boosted 2nd gen... No problems any more. :D
    Although, a first gen v8 tundra would be a blast! Also note, they put the v8 in a 4runner for a bit!
  11. Mar 16, 2017 at 8:54 AM
    #91
    Jrat
    Jrat Member
    2017 D.C. Sr5
  12. Mar 16, 2017 at 8:56 AM
    #92
    Jrat
    Jrat Member
    2017 D.C. Sr5
    Drive a Honda Civic for 10 years and anything seems fast
    Sharky50 likes this.
  13. Mar 16, 2017 at 8:58 AM
    #93
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Nice! Used to go down to RaaaaceWay! Park!! :)
    Sharky50 and Paul631 like this.
  14. Mar 16, 2017 at 9:11 AM
    #94
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    I installed a power pedal deal on my MT, it works. Basically it tell sthe computer your smashing the gas quicker and futher than you really are so I drive it like my 2nd gen and not like a 4 cylinder. It sounds weird but if the truck was set up like this from the factory I would have never complained.
    Im using it in sport mode, the higher up modes make it too snappy.
  15. Mar 16, 2017 at 9:15 AM
    #95
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Link?
  16. Mar 16, 2017 at 9:37 AM
    #96
    JasonCSU
    JasonCSU Well-Known Member
    Denver, CO
    2017 DCSB 4x4 TRD OR 6MT
    That is my guess as well. It seems like many new cars these days have a much less sensitive throttle tip-in.
    goose443[QUOTED] likes this.
  17. Mar 16, 2017 at 9:51 AM
    #97
    Chazmann
    Chazmann A/C TRD Sport V6 4x4 6-MT
    I feel that Toyota picked a wrong motor (3.5L) that has a poor low end torque and poor throttle response. On the paper the peak HP and Torque figures of this 3.5L look descent but not on the streets. The motor's characteristics seem more suitable for higher revving passenger cars not for a truck, and in fact it is used on both Toyota and Lexus badged cars. To make the situation worse Toyota messed up on A/T shifting algorithm or mapping in the ECU that tries to hunt for higher gear whenever possible (to fix this issue a TSB has been issued). To feel the power/torque wanted, the rpm has to be kept at higher range, then the mpg sux. A classic example of double edged sword situation.
    Doomsday, jetfishn, scornwel and 3 others like this.
  18. Mar 16, 2017 at 9:55 AM
    #98
    Specalt
    Phoenix
    2001 TRD 4x4
    I think you have this totaly correct.
    I would bet 2019 sees a new motor.
  19. Mar 16, 2017 at 10:14 AM
    #99
    6172crew
    New Mexico
    4X4 TRD sport
  20. Mar 16, 2017 at 10:18 AM
    #100
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Stickers for sure
    Woodrow F Call likes this.
