I4 2.7 Oil Change Frequency?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vosyer, Jun 14, 2017.
  1. Jun 14, 2017 at 11:07 AM
    Vosyer
    Vosyer [OP] New Member
    2015 Prerunner SR5 2.7 4 cylinder extended cab
    I'm a new owner of a 2015 Tacoma Prerunner SR5 with a I4 2.7 motor . Yesterday I had my oil changed under Tacomacare at my local dealer. It was changed with complete synthetic as called for in owners manual. He said he see me back in the recommended 5000 miles - there in lies my question - 2016 2.7 recommendations are oil change at 10,000 and 2015 2.7 are at 5000 miles. I thought they were the same motor why the oil change frequency difference? Thanks
  2. Jun 14, 2017 at 11:10 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    A lot of service writers are paid commission, so I don't listen to them, however, I changed mine at 5000 or six months regardless. Probably overkill, because I run full synthetic.
  3. Jun 14, 2017 at 11:12 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    2016-2017 2.7 is a different 2.7.
    Dual VVTI or something.
  4. Jun 14, 2017 at 11:14 AM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I change mine at 5k miles also on my 2015, even though the other 0W-20 Toyota models call for a 10k service.
  5. Jun 14, 2017 at 11:15 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I run synthetic in my V6. I still change it every 5K though. Though i did miss (too lazy) an oil change recently, so the last change was at 9k.
  6. Jun 14, 2017 at 11:26 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    99 2.7 was 7500 miles on dino oil according to the manual
  7. Jun 14, 2017 at 11:27 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I use full synthetic in my 2008 2.7L (same as yours), and I go every 5000 miles. I too realize this is probably overkill but it's $30 and takes 15 minutes...I have no problem overkilling it. What's $30 when I spent $750 on gasoline in that same period.
  8. Jun 14, 2017 at 11:30 AM
    tacoma4
    tacoma4 Well-Known Member
    In my opinion, they increase the interval to cheat the "cost of ownership" numbers down. Is 10k OK on synthetic oil in a modern car? Probably, but I'm going to change it every 5k anyway. A few hundred dollars over the life of the vehicle is not worth the risk to me.
    NAAC3TACO likes this.
  9. Jun 14, 2017 at 11:35 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    I change my 2016 SR 4x4 4 cylinder 2.7 every 5,000 Miles with Mobile 1 Synthetic 0W-20 and a OEM Toyota 90915-YZZG2 Filter!
  10. Jun 14, 2017 at 11:41 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Guess I'm against the grain. I go 10,000 on M1 full synthetic with my 2014, always check it at 5k, it's never been low. Just make sure you use a filter capable of 10k also, I use the Bosch extended life.
    JJ Diablo and NAAC3TACO like this.
