I4 ACCESS CAB tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Connellycm, Feb 7, 2018.
  1. Feb 7, 2018 at 7:47 PM
    Connellycm
    Connellycm [OP] Member
    2014 I4 access cab. Auto. Will 265 75r16 tires fit without trimming or modifications.?. If LIFT is needed, then how high?
  2. Feb 7, 2018 at 7:48 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    5 lug?
    No
    6lug?
    Yes
    And
    No need for lift or trim.... maybe mudflap rub if u havent lost them yet
  3. Feb 8, 2018 at 5:40 AM
    Connellycm
  4. Feb 8, 2018 at 5:46 AM
    Connellycm
    I was thinking of installing bilstien shocks on front to add 1.75". Not sure how to do the rear to maintain current rake. Suggestions?
  5. Feb 8, 2018 at 5:49 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Setting Bilstiens at 1.75 ill not keep current rake. You would have to set at 0 if i'm correct, .85 more level and 1.75 level 2.25 will have lean back.
  6. Feb 8, 2018 at 6:30 AM
    inwood customs
    Dave
    Raise the rear with an add a leaf.... preferably a progressive add a leaf.
  7. Feb 8, 2018 at 6:32 AM
    inwood customs
    Dave
    MattCowsmasher likes this.
  8. Feb 8, 2018 at 7:06 AM
    Connellycm
    Thanks for the info.
  9. Feb 8, 2018 at 8:12 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    They'll fit. I get a little full lock rub when I pull into my driveway, but that's about it. No lift, only added 1.5" wheel spacers until I get new wheels.
    Hankook DynaPro ATM 265/75-16
  10. Feb 8, 2018 at 8:16 AM
    Pigpen
    Dan
    Northwest Montana
    5100s at the 1.75" setting lifted my V6. 4x4 Access Cab 2.5"
  11. Feb 8, 2018 at 8:17 AM
    Pigpen
    Dan
    Northwest Montana
    Dakar leaf springs to maintain rake
  12. Feb 8, 2018 at 8:21 AM
    Tiedie
    David
    WFOY
    This ^^^ mine
  13. Feb 8, 2018 at 11:50 AM
    Connellycm
    Both nice looking. Do the 265 75r16 effect power on the I4. What weight tire works best. ALSO, looking for 16" wheel in black. Any recommendations and what offset to prevent any rubbing.
  14. Feb 8, 2018 at 12:00 PM
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I noticed a minor drop in fuel economy and low-end grunt...but then I did my turbo so I can't even compare anymore. I Was coming from awfully bare highway terrain tires, though lol.
    All in all- the switch to the AT tire in 265/75 was well worth it.
    As for wheel backspacing for rubbing- I'm useless there, as I have 1.5" spacers currently.
  15. Feb 8, 2018 at 12:11 PM
    Connellycm
    What make tire
  16. Feb 8, 2018 at 1:41 PM
    Connellycm
    Sorry, didn't see your listing the tire next to your pic. Thanks for the info.
