I4 loss of power and rumbling up hill only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Catskltaco, Mar 1, 2023.
  1. Mar 1, 2023 at 7:57 PM
    Catskltaco
    Catskltaco [OP] Member
    2007 silver Tacoma
    TC UCA, 5100’s, 265/70/17 generals. Double cab leafs w add a leafs. Mbrp cat back on 2.7 w 5 speed.
    While towing just under 3000 lbs 2 weeks ago, going up a very long steep grade on highway, I began to loose power and seemed like the engine was going to blow up. I got off the highway and proceeded to drive at slow speeds on back roads. Truck has been pretty much normal except when I try to push it up long hills it starts to bog down and a rumbling starts shaking the whole truck. What could be causing this?
  2. Mar 1, 2023 at 8:02 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Plugged cat? Is yours a manual or auto?
  3. Mar 1, 2023 at 8:19 PM
    Catskltaco
    2007 silver Tacoma
    Good flow out of exhaust. It is a 5 spd manual. Has 240000 miles
  4. Mar 1, 2023 at 8:28 PM
    kidthatsirish
    Take it on a highway....put it in third gear and speed up till about 3500-4000 rpms...if the cat is starting to go it will start to hiss as it's compressing the exhaust manifold bolt springs to let the air escape.
    Also how is the condition of your clutch?
  5. Mar 1, 2023 at 8:35 PM
    Catskltaco
    2007 silver Tacoma
    Clutch hooks up well, but throw out bearing makes noise when going from reverse to 1st. Exhaust system is a bit undersized in general. I let a cheap muffler shop put a universal muffler on with a short side exit to pass inspection a year ago.
  6. Mar 1, 2023 at 8:37 PM
    Catskltaco
    2007 silver Tacoma
    The cats are about 5 years old. Had them replaced by dealer after they were stolen.
  7. Mar 1, 2023 at 8:49 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Pop the number 4 coil out and if the tip is covered in oil it’s time for valve cover and spark plug tube gaskets. Then I’d replace the plugs with NGK 6619 plugs and buy new Standard Ignition Blue Streak UF495 ignition coils. It worked for me. Good luck!
