IAC replaced 3 times...
Discussion in 'New Members' started by Jarriel, Feb 15, 2025.
  1. Feb 15, 2025 at 2:08 PM
    Jarriel
    Jarriel [OP] New Member
    Suddenly check engine light came on took the truck to have the scanner on it showed IAC it's a 2001 Toyota Tacoma standard transmission replaced it 3 times already reset/relearn it after 40 came on second time after 100 miles . third time at 50 miles.checked gasket, water line everything seems to be ok any one with the same issue?
    buckhuntin-tacoma likes this.
  2. Feb 15, 2025 at 4:21 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Feb 15, 2025 at 4:24 PM
    Jarriel
    Thanks
  4. Feb 15, 2025 at 4:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Any idea what the code number was..?
    I could probably figure it out.
    That would would take skimming over the FSM for IAC codes.
  5. Feb 15, 2025 at 4:33 PM
    Jarriel
    Don't remember the code number but it's the IAC and bought it at the auto parts based on that code checked all vacuum hoses no leaks checked all the wiring check voltages ohms resets relearns so far still same code same engine light
  6. Feb 15, 2025 at 4:35 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Which engine?
    Alot of the non oem iac valves are crap
  7. Feb 15, 2025 at 4:38 PM
    Jarriel
    2001 Toyota Tacoma 3.4 V6.
    first bought at O'Reilly's.got my money refunded second at eBay returned, third at auto zone. reading here did all necessary steps to verify it's not the valve
