IAC screws frozen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Mar 31, 2021.
  1. Mar 31, 2021 at 6:03 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    i have been wanting to remove the IAC, test it, give it a cleaning. I got a JIS screwdriver, no luck. Pb, no luck. Gave them a tap/whack, no luck. Heat, which seemed a little risky given that it heated up the throttle body & thee are electrical connections, no luck. Any suggestions?
  2. Mar 31, 2021 at 8:11 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Vice grips worked for me, but they sure are stubborn.
  3. Mar 31, 2021 at 8:19 AM
    ElTaquitoJr
    ElTaquitoJr Well-Known Member
    01 Tacoma PreRunner 4 cyl
    I took a rotary tool with a cutting wheel and made a straight groove across the head. I then took a flat head screwdriver and spun them off with that.
    If you want to replace the screws afterwards, you can get hex screws but I don't recall the size. If you search the forum, you'll find it.
    Alternatively you can use the JIS screwdriver and take a crescent wrench to the handle to give you more torque. You'll want to put a good amount of downward pressure on the handle so the tip doesn't slip out and wreck the head.
    Rachelsdaddy likes this.
  4. Mar 31, 2021 at 8:41 AM
    Kristi with a K
    Western MA
    Kicking myself for not getting the screwdriver set that had the t-handle. Thank you. Maybe the grips, then the cut if needed.
  5. Mar 31, 2021 at 10:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Time to drill them out .
    Might want to have new screws so you can drive your truck .
    Do you have Access to a Drill Press??
    Makes it much easier.
  6. Mar 31, 2021 at 10:35 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    They can be stubborn. I usually make stern, serious, lengthy eye contact with them while I lightly clamp the t-body in a vice (hint). By this time they "usually" understand who is the boss.
  7. Mar 31, 2021 at 2:16 PM
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Easy thing to do is replace them with normal screws same size with a lock washer on them.
    Kristi with a K[OP] likes this.
  8. Mar 31, 2021 at 4:19 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
  9. Mar 31, 2021 at 6:36 PM
    Kristi with a K
    Western MA
    I got them with vice grips, but it looks like I need some more handy tools :spending:
    Sure glad I got the IAC freed up because it was a mess!
