IAC valve or something else?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaFloppa, Jul 7, 2025 at 4:31 PM.
  1. Jul 7, 2025 at 4:31 PM
    TacomaFloppa
    TacomaFloppa [OP] Well-Known Member
    Went wheeling for the 4th of July weekend, very dusty, following behind people for MILES.
    First day and before no issues, setup camp, sleep through the night, no issues. turn truck on the next day and the truck starts, jumps to 500 rpms, and then dies.
    Only way I found to fix it was go to 3000 rpms while in park, then shift to drive, and after that it idles around 500 and slowly climbs until normal again.
    Now that I'm in lower altitude and clean air, it still goes to 500 rpms but it stays and doesn't die.
    After doing research on TW, I think it's the IAC valve, am I correct in this thinking?
    Spark plugs good, alternator good, battery good, fuel good, starter good, runs great but has issues when starting.
    164k miles 3.4 v6 double cab auto
  2. Jul 7, 2025 at 4:54 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Have you checked the engine air filter?
  3. Jul 7, 2025 at 4:56 PM
    TacomaFloppa
    Not clean but not dirty. I cleaned it as soon as the issues arose and nothing improved. Might buy a new filter and see if that helps since I need a new anyways. Even ran it without the filter and nothing changed.
  4. Jul 7, 2025 at 4:56 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    No codes?
  5. Jul 7, 2025 at 4:58 PM
    TacomaFloppa
    No codes but I don't have access to any of the fancy readers that tell you EVERYTHING. I might need to find someone who can lend me one because you can apparently read what the IAC valve is doing with one
    t0p_d0g[QUOTED] likes this.
  6. Jul 7, 2025 at 6:34 PM
    Glamisman
    Glamisman Well-Known Member
    Get a can of MAF cleaner and clean the MAF before you jump into it.
    THatt, ControlCar and t0p_d0g like this.
