iBuddy Seat Cover or Hammock in Access Cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RonDog1957, Dec 13, 2018.
  1. Dec 13, 2018 at 6:26 AM
    RonDog1957
    RonDog1957 [OP] Well-Known Member
    Ron
    2019 Cement AC OR
    Hey all -
    Taking delivery of a 2019 OR AC in the next few weeks. I am looking for something to put over the rear jump seats for my two 50 lb Boxers. I have read the posts on here about building pet platforms, which seems like a reasonable option.
    I ran across this on Amazon and also on some TW posts:
    https://www.amazon.com/iBuddy-Water...ie=UTF8&qid=1544710317&sr=8-3&keywords=ibuddy
    In looking at the reviews, it seems they are all in four door cabs. Has anyone tried this (or something else on the market) in an Access Cab? I just find it hard to believe there isn't something ready made that is a good/custom fit for these trucks. Seems like there are enough of them out there to make it worthwhile.
    Taco_Coma likes this.
  2. Dec 13, 2018 at 6:52 AM
    Wasatchrider
    Wasatchrider Well-Known Member
    mine is not a Ibuddy but similar hammock style works great with the dogs I didn't build anything underneath just put the seats down and still have room for gear
  3. Dec 13, 2018 at 6:53 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Not much room in the back of an ACCB. Around 12" from the back of my drivers seat to the rear of the cab, with jump seats down. I haven't searched, but I'm guessing the overall lack of room is why you're not turning up much product.
  4. Dec 13, 2018 at 6:59 AM
    RonDog1957
    Ron
    2019 Cement AC OR
    Thanks guys. I appreciate the feedback. I sure hope I can figure a way for them to ride back there or we just made a huge mistake...
  5. Dec 13, 2018 at 8:13 AM
    oruacat2
    oruacat2 Well-Known Member
    Kenny
    Bluegrass Country
    2017 white Tacoma TRD Offroad
    none yet
    The conundrum with the hammocks and access cabs: you need the backseats up so the hammock can attach to those rear headrests, but with the seats up there isn't much space for the two dogs and there's no solid continuous platform for the dogs to sit/lay on.
    FWIW, this is exactly what led me to a double-cab - I have 3 heelers rummaging around back there. haha Good luck.
    Edit - occasionally I have to transport a dog in a large crate, so I'll lay down the backseats to make it more level. I have an old mat - designed for auto mechanics to lay under their vehicles and be more comfortable/off the ground - that I'll lay across the downed seats. If you measure your access cab backseat, you might find one of those to lay across and cover all the "gaps".
    Something like this, if the dimensions are right: https://www.realtruck.com/trackmat-mechanic-mat/
    You could keep the backseats up, allowing for the hammock to attach, but put this mat underneath, across the seats, so the dogs don't fall down into the gaps/spaces.
  6. Dec 13, 2018 at 8:27 AM
    RonDog1957
    Ron
    2019 Cement AC OR
    I hear you and truly appreciate the feedback. Maybe it will have to a homemade platform and no hammock. They won't be as contained but might be the best we can do.
  7. Dec 13, 2018 at 8:33 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    What the heck, this makes no sense. No, you put the rear seats down. Put the headrests UP. build a simple platform like I did. Put the hammock in the back. It fits fine.
    That being said, my wife is only 5'3 and I'm only 5'7 so our seats are a bit forward and I built the platform to take advantage of that. My dog is 40 lbs. She doesn't need that much room. Your challenge is going to be 2 crazy boxers. haha. I'm surprised you managed to get a pic of them sitting still.
    xBloodxLinex and Irons like this.
  8. Dec 13, 2018 at 8:38 AM
    jmneill
    SE
    As mentioned above, the head rests and seats function independently.
    But not much room for two boxers if you need any legroom up front.
  9. Dec 13, 2018 at 10:41 AM
    RonDog1957
    Ron
    2019 Cement AC OR
    I'm 6'6" so we know where the front seats have to go. I may be in for more of a challenge than I planned...at least they ride fairly well
  10. Dec 13, 2018 at 12:21 PM
    ToyTacoTruck
    ToyTacoTruck Well-Known Member
    Dave
    2017 MGM AC V6/AT/4x4
    Dogs fit fine in access cab. Difficulty with Tacoma access cab is no flat floor. Need to add filler for level platform - I carved foam blocks to fit in floor so it was level with storage bins - easy to install/remove as needed but will likely build dropin drawer unit over winter to replace foam blocks. Next option/step if you have no need for jump seats is to pull them out, it frees up valuable inches to remove seats and remove/exchange back wall for flat panel.
  11. Dec 13, 2018 at 4:03 PM
    RonDog1957
    Ron
    2019 Cement AC OR
    Thanks for the reassurance. We do not need the full back seat for humans as we're empty nesters. And we needed the 6 ft bed which makes the 4 door into a land yacht (that won't fit well in our garage). I'm optimistic we'll work it out.
    jmneill likes this.
  12. May 13, 2022 at 12:42 AM
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    That is perfect! We have a Brittany (or he has us) and he goes everywhere with us. I need to make exactly what you have here.
