Ice cooler that fits under stock tonneau
Discussion in '3rd Gen. Tacomas (2016-2023)' started by copter105, Mar 24, 2024.
  1. Mar 24, 2024 at 6:27 PM
    copter105
    copter105 [OP] Active Member
    Las Vegas
    2017 TRD OR Black
    Well as the title suggests, I need a party cooler in the 70-100qt range that can fit under the stock tonneau cover. Anyone got any ideas?
  2. Mar 24, 2024 at 6:32 PM
    WalkingTornado
    WalkingTornado Kind-of Known Member
    2022 Army Green TRD Sport MT
    The Igloo IMX 70 QT will fit. Costco has them for almost half off.
    I have this cooler and it has just enough space. My Tacoma has the OEM bed mat and the Truxedo Sentry CT cover.
  3. Mar 24, 2024 at 6:32 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I had this same problem. The Tacoma box depth isn’t very deep. I ended up going with a fiberglass topper for this and other reasons. But to answer the question, to get by, I had to use multiple smaller coolers, as everything I found at the time was too tall. If I removed the feet, my bed mat, and put the coolers in one precise location (where the cover bars weren’t located, I could get my smaller Grizzlycoolers in.
  4. Mar 24, 2024 at 6:37 PM
    Vinny C
    Vinny C Well-Known Member
    Vince
    NE Ohio
    2019 Cement TRD OR MT
    I have a 52-quart RTIC that fits perfectly under the cover. Two of those would get you to 100.
  5. Mar 24, 2024 at 7:09 PM
    Edaw33
    Edaw33 Well-Known Member
    2022 TRD Sport SW DCSB
  6. Mar 25, 2024 at 5:24 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    I kept the lifetime 77 quart cooler from walmart under my diamondback. highly recommend. I have a 96 quart fridge now and there are times that I miss that cooler.
  7. Mar 25, 2024 at 8:34 AM
    Vinny C
    Vince
    NE Ohio
    Just for reference. There's maybe 1/8" room at the top, not quite enough to fit two side by side longways at the tailgate. I can fit it behind my driver's seat with the front facing the door so I can get in easily. I can get into it if I flip the first section of the cover up. If you used two you would have some different configurations and you might not need a huge 100qt every time you go out anyway. Just an option.
    TRDisrespect likes this.
  8. Jul 9, 2024 at 4:39 PM
    CSVT
    CSVT Well-Known Member
    Ohio
    2021 TRD Pro
    thanks for posting this. Hand wringing over the size, wanted to get one that fits under the tonneau
  9. Jul 10, 2024 at 10:07 AM
    BDSKJChris
    Albany, NY
    before I put the snomaster in I have a lifetime 77 quart from wal-mart that worked great under a diamondback
  10. Jul 10, 2024 at 10:50 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Canyon Coolers out of Flagstaff.
    Expensive but worth it.
    My 55-qt with a block of ice lasted 16 days in Arizona Summer Heat during a trip to YellowStone.
    When we got home there was still a chunk of it left.
    I've since upgraded to a Dometic but if I ever need more, the Dometic and that Canyon would get me through
    a few nuclear bombs.
  11. Jul 10, 2024 at 12:36 PM
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    YETI Tundra 65 fits perfect
  12. Jul 10, 2024 at 12:42 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    I was about to suggest that same cooler. Fits perfectly under the cover. I however had the opposite experience. I couldn't get "good ice" to last more than two days, even with precooling the day prior. I have upgraded to a camp fridge now too though. The days of soggy food and cold wet hands are over for me, ha.
  13. Jul 10, 2024 at 1:52 PM
    copter105
    Las Vegas
    2017 TRD OR Black
    So I bought the Igloo from Costco for $149.99.
    Without the bed mat it fits absolutely perfect. Maybe 1/8th inch clearance if that?
    With the bed mat it's a little tight. I can close the tonneau but here is some pressure on the tonneau cover. If you are going long distance and are hoping for a tight tonneau seal for water and dust then you need to remove the bed mat as the pressure leaves a small gap between the tonneau and the top of the box. I'm happy with the fit anyway. I can't comment on how long ice will stay solid but for my needs it's perfect. I'll post some photos below when I figure out how to do it
  14. Jul 10, 2024 at 2:02 PM
    copter105
    Las Vegas
    2017 TRD OR Black
    This is what it looks like WITHOUT the bed mat.
  15. Jul 10, 2024 at 2:07 PM
    copter105
    Las Vegas
    2017 TRD OR Black
    This is what it looks like WITH the bed mat.
