Ice down shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Jan 24, 2016.
  1. Jan 24, 2016 at 1:28 PM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    This weather got me wondering. Last year I was driving and the roads looked wet. I drove around a while , cars were going slow so I was driving slow. I came to an intersection and was in 4th gear shifted into 3rd gear and the torque of the engine broke lose the back tires (icey intersection) and made the back end go to the right. I was in 2wd at the time since i was driving around a while without any problems. I have firestone airbags (always have 20psi unloaded)with no weight in the back at the time. Is this normal? I put 200 pounds of sand in the back now just in case.
  2. Jan 24, 2016 at 1:37 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I've had a similar thing happen , pretty normal , its basically the same as applying rear brakes
  3. Jan 24, 2016 at 1:48 PM
    magnum922
    I slid sideways about 5 car lengths till it stopped. Didnt hit anything luckly. The dash was flashing like a christmas tree. I wonder if it was in 4hi would the back tires broke loose like that?
  4. Jan 24, 2016 at 1:55 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    4wd doesn't help the truck stop.
    ThorInc likes this.
  5. Jan 24, 2016 at 1:59 PM
    magnum922
    Though maybe it would distribute the torque of the shift to all four wheels evenly so it wouldnt break the rear traction.
    YotaDriver631 likes this.
  6. Jan 24, 2016 at 2:00 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    I wonder what tires you're running, Magnum922.
  7. Jan 24, 2016 at 2:02 PM
    magnum922
    Our subaru has all wheel drive and never breaks traction when downshifting. I think the tacoma shifts harder since its more heavy duty thus breaking traction.
  8. Jan 24, 2016 at 2:03 PM
    magnum922
    running original dunlop tires.
  9. Jan 24, 2016 at 2:13 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There's the biggest issue, especially 5 year old ones. Yes, using 4wd will help prevent skidding when downshifting, but if you loose traction in 4wd you've lost all your traction and your steering ability with it.
  10. Jan 24, 2016 at 2:46 PM
    magnum922
    The truck has about 27000 miles on it. The tires look brand new. I hate to get rid of them until they are worn out.
  11. Jan 24, 2016 at 2:51 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    You can use the downshifting with the brakes to adjust the balance in 2wd, its what I do. Also go out and learn left foot braking in a slippery parking lot. That helps with front end understeer in snow and ice.
  12. Jan 24, 2016 at 2:52 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Tires are the only thing that help with braking in snow and ice. You need a dedicated set of snow tires if you do a lot of snow driving during the winter. As far as ice you just have to brake easy and slow down way before the stop sign/traffic light. Or you could always run a set of studded snows, but for most areas that would be excessive.
    ThorInc likes this.
  13. Jan 24, 2016 at 2:53 PM
    jdg
    jdg Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    Mine had 5000 miles on them when I replaced them, and I've been reel happy ever sense!
  14. Jan 24, 2016 at 2:54 PM
    magnum922
    thanks for the advice guys.
  15. Jan 24, 2016 at 3:23 PM
    addicus24
    I hear ya magnun922. I still have my OEM Ragged Fails with about 12k miles on them. Still plenty of tread left. Don't seem to handle the rain as well as they did new. Whatever tire I replace these with will be good in the rain.
  16. Jan 24, 2016 at 3:25 PM
    magnum922
    Sorry, I just looked at it the tires are Bridgestone Dueler.
  17. Jan 24, 2016 at 4:02 PM
    jdg
    David
    Texas Panhandle
    All the time!!!
    Mine were the "Dunlops", just got my 2015 in August and I've already got 12,000 miles on it, that's why I changed so fast I want something I could depend on. I just went to Cooper A/T3 265 and there quieter, and smother, than those Dunlops were, that's why I'm so happy.
  18. Jan 24, 2016 at 4:48 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    You're right. It's because the extra engine braking from downshifting was going to the rear wheels only. In 4wd, it would go to all four wheels, possibly causing you to understeer instead.
  19. Jan 24, 2016 at 5:08 PM
    tacoma4
    tacoma4 Well-Known Member
    I had similar happen when switching out of 4wd back to 2wd on an icy-ish road. Power went from 4 wheels to 2 and gave me a nice drift.
  20. Jan 24, 2016 at 5:34 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Let the clutch out gently when driving on ice. Brake gently when driving on ice. Accelerate gently when driving on ice.
    In other words, drive like you are driving on... ice! It's slick, Slick.
    HawkShot99 and NeedmoreTaco like this.
