Ice Horse's 1998 TRD Extended Cab
Discussion in '1st Gen. Builds (1995-2004)' started by Ice Horse, Jun 13, 2013.
  1. Sep 17, 2016 at 4:08 AM
    #281
    dbcorvairracer
    dbcorvairracer Well-Known Member
    1999 Supercharged Taco
    TRD Supercharger, 7th Injector, Light bar, Recaro heated seats
    i love this build.
    You get my first post and first subscribe all in one
    TacoBike and Ice Horse[OP] like this.
  2. Sep 19, 2016 at 6:17 PM
    #282
    Ice Horse
    Ice Horse [OP] Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Sweet! Welcome to TW!
  3. Mar 4, 2017 at 2:20 PM
    #283
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    When you installed the trail gear cross member for the bumper did you have to cut off the existing weak cross member that the skid plate hangs from? I had been told that the bumper was bolt on only, but I saw someone's 04 build thread where he had to cut off the cross member. Thank you!
  4. Mar 5, 2017 at 10:36 PM
    #284
    1HItaco
    1HItaco Well-Known Member
    yes i would like to know this also.
    and are those 285/75/16 tires with those Ivan Stewart? looks like you have no rubbing issues with that setup.
  5. Mar 5, 2017 at 10:55 PM
    #285
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm pretty sure you'll have to cut it off - look at the pics here and on her first page, the trail gear cross member looks like it replaces the cheap stock cross member regardless of what year your truck is. Step 4 shows what the frame has to look like for the install. There's nothing in front of the radiator:
    http://www.trail-gear.com/PDF/120176-1-k.pdf
  6. Mar 6, 2017 at 1:12 AM
    #286
    1HItaco
    thanks but those instructions looks like its for the 2001-2004 on the 99-00 models the front cross member (where the skid plate bolts to) is welded in to the frame. doesn't look like the instructions specify on how to install on that different frame?
  7. Mar 6, 2017 at 1:30 AM
    #287
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If the stock skidplate has to bolt up to the trail gear x member then whatever it's connected to prior is going to have to go bye-bye. That was the one thing I wanted to confirm. The more I look at it the more I think it's not going to be a simple wrench spinning job. Here's more on the bumper but again with a different model year. The frame horns are the only difference from what I've read...
    https://www.tacomaworld.com/threads...ow-profile-bumper-for-1st-gen-tacomas.441752/
    Sorry for the threadjack @Ice Horse !
  8. Mar 6, 2017 at 1:25 PM
    #288
    1HItaco
    thanks for the info.
    as far as the tires are concerned are they 285/75/16? and after reading through the posts it seems that the only rubbing issue is with the stock washer fluid reservoir.
    are there no pinch weld mods that need to be done for the 98-00 because of the different style fender flares?
    seems like all the 01-04 needs to be cut and hammered in more than 1 spot for running 285/75/16 without rubbing issues.
    i also have a set of ivan stewart rims with the same lift and same year model as this and i want to run the 285 but i dont want to have to cut up too many areas.
    looks like you flex the suspension out pretty good just want to know about clearance issues with the rim/tire setup you are running.
    thanks
  9. Mar 6, 2017 at 4:02 PM
    #289
    Ice Horse
    Lauren
    Florida
    It's fine! Glad you tagged me as I've been busy! Haha.
    @Dalandser
    @1HItaco
    It was such a long time ago honestly so it's tough to remember but I'm fairly certain we didn't have to remove it. I think all we did was grind on the "frame nipples" a little bit to get it on a little easier. I could be wrong though, but it wasn't a hard job at all from what I remember.
    Yep the tires are 285/75/16 on the Ivan's. The only issues I have is rubbing at full lock on the frame. It never touched the front of the frame in the past but it will get my reservoirs a little now. If I flex out the back hard enough it has snagged a mud flap in the past (took them off) and it grabbed a bolt head from the flare. Messed up my flare a little lol. I've never had to do anything with the pinch welds.
    Has never touched my washer reservoir. I did have to cut off this bottom elbow piece of it to fit my reservoir.
    Dalandser likes this.
  10. Mar 7, 2017 at 1:36 AM
    #290
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
