Ice/moisture on inside of windshield
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maine_Tacoma13, Nov 28, 2020.
  1. Nov 28, 2020 at 3:31 PM
    Maine_Tacoma13
    Maine_Tacoma13 [OP] Well-Known Member
    It’s starting to cool off here and we had a couple of cold nights the other night but it wasn’t a huge temperature swing. Both mornings the following day I had a covering of ice on the inside of the windshield. So today (it’s been around 45 degrees) I went out to pick up a Christmas tree so probably a total of 25 minutes in the truck. I just went out to grab something and the entire cab had moisture on the inside of the windshield which I’m assuming is likely going to turn to ice tonight. It’s about 40 degrees right now so there hasn’t been a change in temp. I checked to make sure all my windows and stuff were closed and they were.
    Is there any way to tell if there is a potential bad seal somewhere or something? I have an extended warranty so I can bring it to the dealership but figured I’d start here to see if anyone has any ideas.
    Also, I had this truck all last winter and never had the issue once.
  2. Nov 28, 2020 at 3:43 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Could be a few things depending on the year of your truck and options that you have
    3rd brakes lights on early models leak
    Sunroof drains can clog and leak
    AC drain hose can clog and leak
    Water can come in from the front door speakers
    You will want to find the source of the moisture.
  3. Nov 28, 2020 at 3:47 PM
    Maine_Tacoma13
    It’s a 2017, no sunroof. Any tips on finding it? Just feel like it’s kind of a needle in a haystack
  4. Nov 28, 2020 at 3:53 PM
    5nahalf
    Erik
    Minnesota
    Check your 3rd brake light, it was a issue on 2016-2017 models. Go into a car wash and then check behind the rear seats for water.
  5. Nov 28, 2020 at 3:54 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You could have a leak somewhere, check to see if carpet is wet anywhere. Check behind back seat, I had a rear window leak on mine while still under warranty.
    But it could just be humidity from the air, especially if the humidity has been high recently. Mine has done the same thing for a few days after a rain. What you describe isn't unusual here in GA where 80% humidity is the norm during some times of the year.
    Keeping the truck closed up won't let the humidity out. On sunny days, even if it is cold, I'll open all the doors and let my vehicles air out for several hours from time to time.
    Using the AC as a dehumidifier even in cold weather will dry out the interior of the truck. People who normally live in more arid areas never think of this. You'll still be blowing hot air if your temperature selector is set on hot.
    Maine_Tacoma13[OP] and Tullie D like this.
  6. Nov 28, 2020 at 3:55 PM
    Toytruckmike
    Toytruckmike Well-Known Member
    Michael
    Amarillo, Texas
    07 TRD Sport AC 6sp 4x4 Gone:18 TRD Sport 4x4 double cab. Cement
    Not much on the 07 yet. 18 is gone, but was a greata truck. TRD Pro grill, Gator FX3, Homelink mirror, Black out badges & exhaust tip, Remote start. Future TRD exhaust, skid plate.
    Maine_Tacoma13[OP] likes this.
  7. Nov 28, 2020 at 4:35 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    There are multiple threads on this topic ...
  8. Nov 28, 2020 at 4:45 PM
    Maine_Tacoma13
    I found a couple that we’re just like “moisture is getting in, put some of those packs you get in shoes in there”. Hoping for some better direction.
  9. Nov 29, 2020 at 3:19 PM
    Maine_Tacoma13
    Looks like it might be the 3rd brake light or rear window. Put my seats in the back down and it was wet on the plastic behind the seat
  10. Nov 29, 2020 at 4:16 PM
    egb1776
    egb1776 Well-Known Member
    2017 Tacoma OR
    Do you have any in channel window vents? The weather tech ones on my dodge deformed the seal slightly and on certain days I’d have moisture built up. If not I’d check your third brake light or start pulling up carpet in the foot well areas and see if you can find traces of moisture.
  11. Nov 29, 2020 at 5:19 PM
    Maine_Tacoma13
    I do have in channels. I’m thinking it’s more back window/3rd brake light but not ruling anything out. Moisture is right behind the back seats. 3rd brake light seems very slightly not flush against outside. Hoping to call the dealership tomorrow, bought it used last year and bought extended warranty but not holding my breath.
  12. Nov 29, 2020 at 5:35 PM
    egb1776
    2017 Tacoma OR
    Mine leaked, they replace it with a much thicker gasket that looks like crap to be honest. I’ve been thinking about upgrading to a meso light housing instead.
