Ice road conditions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MJR, Jan 18, 2016.
  1. Jan 18, 2016 at 9:10 AM
    MJR
    MJR [OP] Well-Known Member
    Mickey
    Salado, TX & Santa Rosa Beach, FL
    ‘23 LIMITED 4wd NIGHTSHADE & ‘23 T4R TRD ORP
    Removed factory bed cover and installed UnderCover Elite. Added LOCKERDOWN console safe.
    2014 TRD/OR 4X4 4dr SB: not much ever ice in Central Texas but going to be driving up North.
    Thinking of a few bags of sand over or just rear of axel. What would be a good amount of sand (lbs)? Also would over or just rear of axel be best?
  2. Jan 18, 2016 at 9:18 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I don't add weight to my truck. How far north are you heading? For most conditions in the lower 48, the ice doesn't get cold enough to give much traction at all. I run studded snows to help with traction in the event that I'm out on the road and it ices up. Best advice would be not to drive during an ice storm - I really try not to. Now for snow, that's a different story - still no weight (for me) and use 4WD if road is covered over. Going farther north where it gets really cold? Have to wait for the guys from AK or Canada to chime in.
    Edit: Not to sound like a wise ass but - if you do add weight, make sure to tie it down. Your tailgate, back of cab, and possibly other drivers will thank you if things go wrong.
    MJR[OP] likes this.
  3. Jan 18, 2016 at 9:23 AM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    it was -13 F when i drove to work this morning, never bothered adding weight to the bed in the 6 years ive had the truck. 4 wheel drive will get you wherever you need to unless you plan on playing in deep stuff, and if thats the case, youll need more than sand.
    MJR[OP] likes this.
  4. Jan 18, 2016 at 9:33 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Yes, adding weight directly over your rear axle, securing it so it doesn't slide around will help you with gaining traction. That's what two wheel drive trucks do. Biggest difference you can make is using winter tires on all four wheels.
    200-300lbs works.
    NAAC3TACO and MJR[OP] like this.
  5. Jan 18, 2016 at 9:38 AM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Good set of AT's or studded snows and common sense! Just because the speed limit is 75MPH doesn't mean you should drive that fast if its icy or snowy.
    Good luck from a Northern Canuck!
    MJR[OP] and VE7OSR like this.
  6. Jan 18, 2016 at 10:37 AM
    Riverratsl
    Riverratsl Member
    Scott
    West tennessee
    2005 4x4
    One size bigger tire then stock.
    Two 80# bags of quick Crete work for me . Over the rear axle or against. The front of the bed.
  7. Jan 18, 2016 at 10:39 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Fuck that, get sideways and git-er-dun :p
    Jk
    No I'm not
    But throw two on each side and you should be good
    HawkShot99 likes this.
  8. Jan 18, 2016 at 11:36 AM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    I've never put anymore weight in the back of my truck than an unshoveled, snow filled bed. This has been an ugly winter for us with lots of freezing and thawing, following wet snow (which quickly turns to compact ice). I've just driven in 4H more often. I've used studded tires in the past, but have so far gotten away with a good set of AT tires (Duratracs) without any major issues. Just be cautious with your stopping distance.
    It never hurts to throw a couple hundred pounds of bagged sand/gravel in the bed. If you do I suggest you make a quick run to the hardware store and pick up some 2x4' to build a crib for it between the rear wheel wells in the bed. That should keep it from sliding all around. Plus, if you really get stuck the sand/gravel will could be used for added traction.
    robm7 likes this.
  9. Jan 18, 2016 at 5:59 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I put a 100 to 150 lbs of sand and gravel sealed in old inner tube halves (wire tied ends) against the tailgate. Helps a bit with traction and is good to have unfrozen sand/aggregate available to put down on frozen boat ramps, frozen parking lots, etc. It never moves on a rubber bed mat. If you have the slip-n-side stock bed put it in totes and strap it down.
  10. Jan 18, 2016 at 6:13 PM
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Duratracs have been the best thing I've done to prepare for winter in a long time- snowflake rated tires- it's a thing. The duratrac is an aggressive AT and all of those tread blocks are siped. VERY good snow/ice traction. That said, ice is ice... And just not very good for driving on!
  11. Jan 18, 2016 at 6:21 PM
    gearcruncher
    Canadain bumper technician
    I drive the ice roads to work every day . This is driving over frozen lakes as it saves me about 35 minutes to and from work . I highly recommend studded winter tires if you plan any kind of ice road travelling .The studded tires help but you are going to need weight in the box as well . For this I use 6 fifty pound sand bags over the rear axle . I can pretty much go anywhere on the lake providing the slush level is at a minimum .
    Need a video , just ask and I can post a couple
  12. Jan 18, 2016 at 6:30 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Are you up in the NWT?
  13. Jan 18, 2016 at 6:42 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Most of the replies dealt more with snow than ice. Your 4 door already has more weight over the rear wheels. I wouldn't worry about adding weight to this truck. Truthfully nothing short of chains, cables or studded tires will help much on ice. Especially if any grades are involved. On level ground, and if you drive carefully you can do OK without anything special. Studded tires are great if you live in snow/ice for months at a time. But for a Texan headed north I'd buy a set of tire cables. For heavy duty use in deep snow chains really are better. But for occasional use on 1-2" of snow or ice cables work just fine. They are cheaper, lighter and much easier to install. Also, if you are in an area where ice is patchy and you occasionally have sections of clear pavement cables are better than chains. You don't want to run chains at all on pavement. Cables are OK for short distances at slow speeds. It is a PITA to take chains on and off as conditions change. You don't say where up north is. Kansas, Nebraska and the Dakotas will be much different than the Rocky Mt states. In the mountains you really need chains.
  14. Jan 18, 2016 at 7:00 PM
    906UP
    906UP Well-Known Member
    U.P. of Michigan
    18 SR5 4WD, 17 Tundra CM-TRD
    I travel all over Michigan.....and the midwest for work so I've seen it all from 12+ inches of snow on the expressway in the North to freezing rain & ice along the Mi/In/Oh border. I run Michelin LTX MS2's with 2 70lbs sand bags over the rear axle when the topper is on, 3 bags if I have the tonneau cover on. Rarely need to use 4WD. Studded tires are illegal in Michigan.
  15. Jan 18, 2016 at 7:44 PM
    gearcruncher
    Northern Ontario .
  16. Jan 18, 2016 at 10:05 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I go looking for snow and there's usually ice around too been in a couple situations with my truck loaded up with lots of weight in the bed in the form of gear and rtt and it did sweet fuck all. When it comes to ice if you're not running chains or studs sooner or later it comes down to steer and pray... best solution is to take it easy and don't panic when you start to slide around. Also invest in a set of v bar chains for your truck if you're hitting icy roads all the time nothing beats studed snowies
  17. Jan 18, 2016 at 10:15 PM
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    Don't worry about it just drive. If you happen to get into winter conditions your 4 wheel drive will do just fine. I drive on snow and ice weekly and only put it in 4x4 if I feel I want to rally.
  18. Jan 19, 2016 at 9:16 AM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    For myself I just have about 150 - 200 lbs of sand in the back, winter tires, 4x4 when needed and drive according to the road conditions. Has yet to let me down.
