Icon 1.5” progressive AAL leaf
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jetboy818, Nov 2, 2018.
  1. Nov 2, 2018 at 4:40 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Doing a leaf swap is actually easy enough to do in a driveway if you have a buddy to help lift the pack.
  2. Nov 2, 2018 at 4:40 PM
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Hey guys... what’s the height difference with lift on a 3 leaf AAL and Dakar mediums? 1.5” vs. 2”? Also I’ve heard the CB drop and possible shims if going Dakars?
  3. Nov 2, 2018 at 4:41 PM
    Jetboy818
    Jetboy818 [OP] Well-Known Member
    Lax
    2019 Cement D-Cab Tacoma Trd Off Road 4x4 M/T
    4K budget.
    sierra141 likes this.
  4. Nov 2, 2018 at 4:44 PM
    roguegs
    Angelo
    V8 T4R
    I had the 3 leaf AAL and needed shims. I installed the Dakars and don't need shims but I did the CB drop. The Mediums will give you 2" if you are carrying a load of 300lbs constantly. My buddy had his installed with no weight added and he was sitting ass high but now it has settled in.
    I have the heavy pack which supposedly can handle 600lbs but I have a camper shell and I sleep in the back. The leaf pack is sturdy as shit. While I was camping with my ICON AAL I was nearly riding my bumpstops when I was sleeping with me and my gf.
  5. Nov 2, 2018 at 4:47 PM
    ejewels
    CT
    Oh man so If have no weight in the truck with Dakar mediums I’ll be over 2”?
    Also what’s the likelihood of needing shims with the 3 leaf AAL?
  6. Nov 2, 2018 at 4:48 PM
    roguegs
    Angelo
    V8 T4R
    Yes until they are settled in. After install you would be sitting like 3" or so higher so what you should do is carry around some sand bags or something to break the leafs in
  7. Nov 2, 2018 at 4:49 PM
    ejewels
    CT
    I guess with 6112s at 5/6th notch at 2” it wouldn’t be that bad
    So 2” once settled?
  8. Nov 2, 2018 at 4:51 PM
    Jetboy818
    Lax
    How much front lift is needed to match the Dakars mediums
  9. Nov 2, 2018 at 4:53 PM
    roguegs
    Angelo
    V8 T4R
    I would say that would be the ballpark. I am running 4/3 with 700lb springs with the Dakar Heavies in the back and I like the rake.
  10. Nov 2, 2018 at 4:54 PM
    roguegs
    Angelo
    V8 T4R
    My friend did 3" in the front but with 5100s with some OME springs.
    The rear is 1.5 inches higher than the front stock.
    ejewels likes this.
  11. Nov 2, 2018 at 5:07 PM
    bzzr2
    bzzr2 Well-Known Member
    I personally found the OME fronts very clunky, they’re slightly shorter than the stock assembly iirc and didn’t impress me. Going over speed bumps was rough and they alsways topped out, off road they were no better. This time around I am going to try the eibach front setup from Toytec. I had fox 2.0 on my ford and they were really nice riding all around. Just wait, shortly ppl are going to tell you they suck and to get kings or icons...!
    roguegs likes this.
  12. Nov 2, 2018 at 5:10 PM
    roguegs
    Angelo
    V8 T4R
    People will always say get Kings but I rode with my other friend who had them and couldnt tell any fucking difference in ride quality in comparison to my 6112s. High speed desert runs, sure I would recommend those high end RACING shocks but for majority of people who are weekend warriors will be fine with a mid tier setup.
  13. Nov 2, 2018 at 5:14 PM
    bzzr2
    Agreed.
  14. Nov 2, 2018 at 5:19 PM
    ejewels
    CT
    So 6112s at 5/6 with Dakars mediums with no weight would then give me about a 2” rake? Or maybe back to stock rake once it all settles?
  15. Nov 2, 2018 at 11:14 PM
    #35
    roguegs
    Angelo
    V8 T4R
    I think stock rake
  16. Nov 11, 2018 at 7:23 PM
    #36
    Trdsport19
    Trdsport19 Active Member
    dan
    2019 magnetic grey metallic trd sport DCSB
    Wondering if I go with the icon 3 leaf aal and leave the stock overloads on and get 2” of lift will the icon 2.0 rear shocks for 0-1.5” lift work ok? Any input greatly appreciated!
