icon 2.0 rear reservoir shock install questions
Discussion in 'Suspension' started by AZ4point0, Feb 27, 2015.
  1. Feb 27, 2015 at 7:34 PM
    AZ4point0
    AZ4point0 [OP] Well-Known Member
    V
    Northern AZ
    Tacoma TRD Off Road
    Tacoma TRD Off Road, V6, S/C, Icon Stage 1, TRD Exhaust, AFE Intake
    This may be a dumb question - however,
    does it matter if the reservoir gets mounted toward the front or back on the frame on the shock install? i know the hole needs to be drilled for the bracket but just wanted to make sure what the better option was in this application. (2014 Tacoma)
    Thank you
  2. Feb 28, 2015 at 6:29 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'm not an expert but I don't think it matters as long as the line connecting the res to the shock isn't stretched/crimped/etc. Most I've seen have the res behind the shock toward the rear of the truck though.
  3. Feb 28, 2015 at 8:35 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Youll find they have a bit of a natural orientation once you install the shock.
    For mine its basically driver side rear the reservoir is towards the front. The passenger side is towards the rear. Has to do with how the shocks are laid out.
  4. Feb 28, 2015 at 10:37 AM
    AZ4point0
    V
    Northern AZ
    Tacoma TRD Off Road
    thanks - i realized that too after i put them on
