Icon 2.5 C/O non-res rebuild with pics
Discussion in 'Suspension' started by jjbeenken, May 22, 2011.
  1. May 22, 2011 at 11:12 PM
    jjbeenken
    jjbeenken [OP] Well-Known Member
    Big Daddy Woo Woo
    Arkansas
    2010 Taco double cab (under construction)
    Hertz-Arc Audio-PPI-Image Dynamics-Pioneer F90BT-Icon Coils-AP UCA's-Dakar Springs-300 shot NOS!
    Home made compressor. I will modify this one.
  2. May 22, 2011 at 11:13 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
  3. May 22, 2011 at 11:14 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
  4. May 22, 2011 at 11:16 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
  5. May 22, 2011 at 11:18 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
  6. May 22, 2011 at 11:18 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    Disassembled shaft with new parts
    Removing the seals are a little tricky. They are very rigid. Using a very sharp pic like I was able to to insert it in the seal to pry it out and then get a rounded flat bladed screwdriver behind it. This made it very easy and not tear up the seal head.
    New seals installed
  7. May 22, 2011 at 11:19 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    Machine screw fell out of the piston and bounced around for a while apparently. Good thing I took these things apart before pit them on. This shock was low on oil and nitro, not sure its related to the screw or not. The other shock still felt pretty good with the spring off.
    Sirmeeps likes this.
  8. May 22, 2011 at 11:19 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    Shaft before
    After (I did clean up that spot in the center) 320 to 800 then 1500 grit
    Shock body after touchup
    With this high dollar piece of equipment.
  9. May 22, 2011 at 11:20 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    Set dividing piston
  10. May 22, 2011 at 11:20 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    This is just a look inside. Read the link below from TS. It is a great write up and frankly more ambitious than I am. Hats off to him for a great read!!
  11. May 22, 2011 at 11:24 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    Hey mods how do I fix my misspelled title?????
  12. May 23, 2011 at 8:24 AM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    thanks mjp2, it was a late night last night:drunk:
  13. May 26, 2011 at 2:05 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i have a few if you dont mind...
    1 - im just wondering about exactly how much oil do i refill the shock with.
    2 - do you have to de-pressurized the shock before you take it apart? if so, how do you do that? (i have a set of the DR coilovers, but i believe the nitro fill up valve is the same.)
  14. May 26, 2011 at 2:20 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    1 - You need to set the dividing piston depth with the shaft assembly. Move the seal head all the way to the end of the shaft and push the dividing piston down until the groove on the seal head is even with the shock body. Then fill the shock up to about an inch from the top. You then bleed all of the air out of the shock. Before you put the seal head in top the shock off so some oil spills out. You do not want any air in the oil.
    2- Don't let the nitrogen out until you unscrew the cap on the the bottom of the shock or the seal head will turn. You then let the nitrogen out with a nitrogen needle and then push in the seal head to take the C-clip out. The shaft then pulls out.
  15. May 27, 2011 at 5:08 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    hehe, you said "seal head"
  16. May 27, 2011 at 1:08 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    Here's a great write up.
    http://www.tundrasolutions.com/forums/suspension-and-axle/97686-teamwest-coilover-r-and-r/
  17. May 27, 2011 at 1:10 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ sweet dude, appreciate that!
    also, did you use shock oil from DSM, or where and what brand did you use?
  18. May 27, 2011 at 7:26 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    No problem. I just found that today. Kinda makes this whole post a waste. Just put mine together and went flawlessly. I'll charge them tomorrow at the shop and I should be set.:pray:
  19. May 27, 2011 at 8:43 PM
    jjbeenken
    Big Daddy Woo Woo
    Arkansas
    New pics added
  20. May 28, 2011 at 1:01 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Nice job. Especially with cleaning up the shafts. I did the same thing to mine because the new seals will quickly become destroyed if the shaft is scarred up. I'm sure they'll give you years of good service now. Removing those seals from the seal head is a delicate matter eh? Definitely something to watch out for when DIY.
