Icon 2.5 C/O's with Winch and Bumper
Discussion in 'Suspension' started by High-Gear, Apr 28, 2010.
  1. Apr 28, 2010 at 7:29 PM
    High-Gear
    High-Gear [OP] Zombie Killer
    Newton, KS
    09 TRD Off Road
    TRD Supercharger, TRD Cat Back Exhaust, DR / Icon 2.5 Coilovers, Camburg UCA, TSB with AAL, Walker Evans 2.0 reservoir rear shocks, ARB Bull Bar, Smittybilt 10K Comp Winch, ARE Camper Shell, Con-Ferr Safari Rack, 4 KC Highlights on rack, 2 KC Rallye 800 on Bumper Armortech Off Road plate rear bumper. Firestone Airbags in rear, with Firestone compressor.
    Hello,
    I originally posted this in the 2nd gen forum, but think it is more appropriate here.
    I have a 09 TRD off road and I have been looking at which coilovers to install with the intent of eventually addind an ARB bumper and winch. From what I have read the SAW's use a 650 lb spring and should be good to go when I add the extra weight, but I may have to crank it up a bit to bring it back to level.
    I was looking at the ICON site, an it said something to the effect that it may be a no go with a winch / bumper as it will make the front sag.
    Do the ICON / DR co's use a lighter weight spring? What is the spring weight? Will I be good to go with the ICON 2.5?
    One a side note, is there any difference in the C/O's that say DR on them and the newer ones which say ICON, or just the leftover stock from Donahoe?
    Thanks
  2. Apr 28, 2010 at 7:32 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    I have the ICON's right now with a baja style front bumper and will soon be changing to a plate style bumper with winch. You should be good, there are a few people on here that run this setup with no problems.
  3. Apr 30, 2010 at 9:22 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I've seen a few people a while back complain about having to crank there CO's too much to compensate for the added weight. Gave them a rougher ride. Can you get different springs with icons? I think silverback got longer ones with his fox set up.
  4. Apr 30, 2010 at 9:30 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    The Icons use a 650 lb spring.
