Icon 2.5" remote resi rear shock official "Road test"
Discussion in 'Product Reviews' started by chris4x4, Mar 29, 2011.
  1. Mar 29, 2011 at 11:18 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I got a chance to go test these today, and Im impressed. The test was done on a 25 mile off road loop that I have tested other shocks on. With the Icons, I was able to push things a little faster than other shocks I have tested in the past.
    First impressions:
    The low speed dampening is boardering on the very firm/stiff side. Below 25 mph things are kinda harsh. around 30 to 35 mph things smooth out, and at 45 mph (wash board, rutted, with some good size holes, washes, rocks, etc.) things become absolutly wonderful. Under acceleration on ruts, rocks, uphill, the back end was planted the whole time. Sliding around corners, off and on power, the truck was completely stable. Even when pushed to the edge, the back end felt composed, and seemed to comunicate its actions well. The ambient temp was 77*, and the the hottest I could get the shocks up to was 88 to 90*, while the remote resi stayed at ambien temp. The fronts (in comparison) got up to 87 to 89*. These are a perfect match for those who are running a digressive rate 2.5" front CO. The only changes I would suggest is a softer low speed dampening.
    Weirich likes this.
  2. Mar 29, 2011 at 11:22 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    Great info Chris! I' considering these when I lift! Thanks! :thumbsup:
  3. Mar 29, 2011 at 1:57 PM
    merrit
    merrit Well-Known Member
    Las Vegas
    seriously depussified oc to
    I knew you would like them.
  4. Mar 29, 2011 at 2:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was disapointed that the N2 pressures were way off out of the box, but.....thats an easy fix.
  5. Mar 30, 2011 at 10:57 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    I noticed on the street that bumps are a bit harsh (maybe the Alcan springs) but pot holes and dips are absorbed nicely! Haven't seen any dirt yet still waiting on lugnuts to mount new wheels and tires.
  6. Mar 31, 2011 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. The low speed dampening is a bit firm.Softening that up should make the shocks perfect for the Tacoma. I have a feeling they are valved for the FJ.
  7. Mar 31, 2011 at 11:11 AM
    merrit
    Las Vegas
    Thats why they are adjustable... I figure the sales dude would be able to get that checked FOC ?
    That very well may be. ...try it with a couple 3 hunderd #s of gear tied down behind the cab and run it .. tell us what you think then...
  8. Mar 31, 2011 at 12:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Why do I need to outfit my truck in a way that I dont run it? Being as I have a quad cab (already heavier than an ext. cab.) and about 150# of tools, I feel my comparisons are fair. If you have an issue with the way I tested, by all means, get yourself a pair, and conduct your own test. Be sure to get the OME's, 5100's, Ranchos, etc. so as to be able to offer a true comparison. All of my tests in the past have been in the same vehicle, configuration, trail, and testing shocks "Out of the box", with only adjustments made to N2 psi.
  9. Mar 31, 2011 at 1:02 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hey great info chris!!;)
  10. Mar 31, 2011 at 1:05 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 :cool:
  11. Apr 1, 2011 at 10:57 PM
    06rubi
    Kenney
    Pueblo West, CO
    Hey Chris, what psi were you at on your test run? Do you think tire pressure was in the equation at all when Icon developed these shocks?
  12. Apr 1, 2011 at 11:49 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Hey chris, you said that the shocks would be a perfect match for digressive rate c/o, I have some camburg c/o's going in soon, are they digressive by any chance?
  13. Apr 2, 2011 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I run street pressures so as to feel the shocks without having the tire pressure play a role in the feel. Im going to be talking to Jeremy at Icon on Monday regarding what tire psi's may have been in mind for these shocks. ALso, Sonny at Downsouth Motorsports is re valving teh low speed compression for me. WHen they are back to me, I'll give them a go, and see what improvements it makes.
    The only Digressive shocks readilly availible for the Tacomas (that I know of) are the Icons.
  14. Apr 17, 2011 at 7:04 AM
    06rubi
    Kenney
    Pueblo West, CO
    How much lift do you have in the back Chris? Following my wife last night I noticed her shocks only have about 4" (just a guess) of compression left on her shocks. We only got about 1.5" lift out of the Alcan springs. Point being Icon says last couple inches is internal bumpstops. Could the harshness be a bit of the bumpstop compression? Just a guess. The ride has gotten better since the springs have broken in. I finally welded on the factory bumpstops (u-bolt flip) last night so we can go flog it now to see how it does off-road.
  15. Apr 17, 2011 at 7:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im at 1.75" lift in the rear.
    If you have the 2.5" resis like mine, the inital compression is firm, but off road, and on big hits, its softer.
  16. Apr 21, 2011 at 3:02 PM
    DevL
    DevL Well-Known Member
    The internal bump zone is only 20% more dampening, which is not that much after 2 or so inches of travel. The low speed harshness is inherant to digressive valving, as is the high speed smoothness. You cant have it both ways.
  17. Apr 21, 2011 at 3:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sonny at Dounsouth Motorsports took a little of the low speed dampening away to help make them a little bit softer initially. I havent had them off road yet, but the on road ride is nice.
  18. Apr 21, 2011 at 7:50 PM
    DevL
    How would you compare it to the stock Bilstein TRD shocks as a reference (my only real digressive truck experience)? Mine seem stiff on road yet bottom out ridiculously easy offroad.
  19. Apr 21, 2011 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are a little more firm on the road, but off road, they are fantastic. Below 20 mph or so, the ride is firm, but as speeds increase, the ride gets better. The normal stretch I test shocks on is pretty harsh at 45 mph on other progressive shocks, but I was way over 55 mph with the Icons. Not sure how fast I was going, but at one point I hit the rev limiter in second, then shifted to 3rd.
  20. May 4, 2011 at 8:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Update:
    I took a little more PSI out of the rear shocks. Im at 100 psi now. They seem to be sofening up a little more. Still more firm than the 5100's, N182's I have run in the past with my current springs. Articulation has increased about 2.5". I'll be testing with a load (500#) on Saturday.
