Icon 2.5 resi clunking
Discussion in 'ICON Vehicle Dynamics' started by Benjamin_PDX, Feb 26, 2018.
  1. Feb 26, 2018 at 5:03 PM
    Benjamin_PDX
    Benjamin_PDX [OP] Member
    Mount.Tacoma
    Clackamas, Oregon
    2016 Black Tacoma TRD Sport DCSB
    My Icon front suspension is clucking when going off little drops or up the driveway. Any idea what this noise could be? Thanks in advance for any help.
  2. Feb 26, 2018 at 5:04 PM
    doorsidedown
    doorsidedown Well-Known Member
    Did it just start doing it? How long have you been running them?
  3. Feb 26, 2018 at 5:06 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Looking at how much preload (too much) you have I'm gonna say you're getting coil bind
  4. Feb 26, 2018 at 5:07 PM
    Benjamin_PDX
    Mount.Tacoma
    Clackamas, Oregon
    The noise has been around since the lift. I have been running them for about 2 months.
  5. Feb 26, 2018 at 5:07 PM
    Dillypoop
    Dillypoop Well-Known Member
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    aaaaaand another one
  6. Feb 26, 2018 at 5:13 PM
    doorsidedown
    I can’t see the pic, signal is bad here, but that would do it. Mine don’t clunk at all.
    another what?
  7. Feb 26, 2018 at 5:14 PM
    TireFire
    Olympic Peninsula
    Looks like over 2"
  8. Feb 26, 2018 at 5:16 PM
    Benjamin_PDX
    Mount.Tacoma
    Clackamas, Oregon
    I will bring it down a bit and hopefully the clunking will go away! Thanks guys. Ill post up the results.
  9. Feb 26, 2018 at 5:17 PM
    doorsidedown
    That’d do it. Might want to look into a 14” spring OP. assuming you’re running the 13” 650lb spring.
    Or crank it down a bit.
  10. Feb 26, 2018 at 5:22 PM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    another person just cranking on the preload for a lift. not what these shocks are meant to run.
    it could be coil bind or it topping out (not enough rebound damping) also from too much preload. call icon and get their recommendation on what spring to run. they SHOULD help you.
  11. Feb 26, 2018 at 5:22 PM
    doorsidedown
    Ah. Gotcha. Good advice here OP.
  12. Feb 26, 2018 at 5:24 PM
    tcjacado
    tcjacado Well-Known Member
    Benjamin_PDX[OP] likes this.
  13. Feb 26, 2018 at 5:36 PM
    Benjamin_PDX
    Mount.Tacoma
    Clackamas, Oregon
  14. Feb 26, 2018 at 5:47 PM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    how much droop do you have? what rate springs?
  15. Feb 26, 2018 at 6:11 PM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    Also, are these "CDCV" clickers only compression adjusters?
  16. Feb 26, 2018 at 6:38 PM
    Benjamin_PDX
    Mount.Tacoma
    Clackamas, Oregon
    I will measure droop tomorrow and let you know. I have the 650 spring rate. The reservoirs have no CDCV clickers.
  17. Feb 27, 2018 at 12:17 PM
    Benjamin_PDX
    Mount.Tacoma
    Clackamas, Oregon
    Droop is at 2.5 inches.
  18. Feb 27, 2018 at 12:23 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Common issues and things to check:
    Check the torque on all bolts in the area shock mounting top and bottom, LCA, UCA, spindle adapters top and bottom, EVERYTHING.
    Cant tell if you have the sway bar attached, make sure it isn't contacting anything if it still is.
    Check the tie rod clearance to the shock, if the lower rod eye spacers are installed backwards you can have clearance issues.
    If the issue happens when the the suspension droops out, jack up the truck and check for interference issues.
  19. Feb 27, 2018 at 12:37 PM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    It could be the combination of too much pre-load as well as having the sway bar still attached.
    Preload pushes too much on the shock since there's not enough damping and the sway bar does the same (pulls down un-compressed side making it top again. Does it do it on a square hit (both wheels hitting at the same time)?
    Could be something loose on the sway bar as well.
  20. Feb 27, 2018 at 12:38 PM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    Did you measure with one side off the ground or both?
