Icon 3 leaf pack problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yotatotaco77, Sep 26, 2018.
  1. Sep 27, 2018 at 2:18 PM
    #41
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you add the 1/4" anti-lean top plate spacer on the driver side? If not you'll get more lean.
    I drilled my overload pin out, the BFH'd it off.
    Chase8059[QUOTED] likes this.
  2. Sep 27, 2018 at 2:51 PM
    #42
    yotatotaco77
    yotatotaco77 [OP] Well-Known Member
    Southern Oregon Coast
    2011 Tacoma TRD off-road extended cab
    Bilstien 6112s with 700# springs ARB Deluxe Bull Bar 9k winch Bilstien 5160s Icon progressive 3 leaf AAL
    No, I didn't add the spacer, the 6112s are adjustable, but they have to be taken out and all that BS. Might be something I'll have to do. The front doesn't have as bad of lean, only about a 1/4 inch high on the passenger side.
  3. Sep 27, 2018 at 10:01 PM
    #43
    SoCalBurrito760
    SoCalBurrito760 Member
    2018 Tacoma OR
    Piggybacking off this thread as I just recently made a similar post.
    I ordered the ICON add-a-leaf for my 18 OR and I too noticed the center pin wasn't fully threaded.
    Better yet the instructions from icon state to keep the overload spring off, but without it how does the add-a-leaf produce any lift as the overload is almost the same thickness.
    Pics for reference.
  4. Sep 27, 2018 at 10:08 PM
    #44
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Looks like you also got the wrong center pins. The AAL ads more arch to the spring pack to create the additional lift.
  5. Sep 27, 2018 at 11:00 PM
    #45
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Installed my icon AALs today. Same issue. I ended up re using the factory pin (it barely fit) I wanted to re use the overload springs for a little extra lift, but it only takes a few minutes (literally) to swap em back in. I was pretty irritated with icon for using a pin that has a really long shank and almost no thread. To make this pin work, you’d need 2-3 more leafs. Happy with the rest of my stage 2 kit, but I feel they messed up some where along the line when putting the AALs together.
    SoCalBurrito760 likes this.
  6. Sep 27, 2018 at 11:04 PM
    #46
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Facepalm to self.
    Right, if leaving the overloads out you reuse the factory pin. If leaving them in you use the new pin. Jack up the axle to compress the leafs before putting the nut on the center pin and you should have no problem with the OEM pin.
  7. Sep 27, 2018 at 11:09 PM
    #47
    93yotasr5
    Sacramento
    When using the overload spring the icon supplied pin still wouldn’t work. My pic is showing the exposed shank with the overload spring installed. I had to remove it and use the factory pin.
  8. Sep 28, 2018 at 2:30 AM
    #48
    yotatotaco77
    Yep, same exact problem I had, even with overload springs left in, the centering pin bolt that came with the kit was way to long and didn't have near enough threads. I had to go to the dealership and get new centering pins, $2.50 each, I tried my local Orielys and they would have had to order them in. The guy at the dealership said Napa usually has them in stock also. Seems like icon let out a bunch with this same issue
  9. Sep 29, 2018 at 12:06 PM
    #49
    Jsloan128
    Jsloan128 New Member
    2015 Black TRD Sport
    Could always use a die and add threads, then cut the excess off.
  10. Sep 29, 2018 at 1:20 PM
    #50
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    I pretty sure you can get a new free 3 leaf plus overload pack installed by aToyota TSB.
  11. Sep 29, 2018 at 1:27 PM
    #51
    lynlan1819
    Tacoma
    Lifted
    Drive your truck for a couple weeks too let the spring's settle,than remeasure.
  12. Sep 29, 2018 at 1:29 PM
    #52
    lynlan1819
    Tacoma
    Lifted
    Icon need's too get their crap together.
  13. Sep 29, 2018 at 3:29 PM
    #53
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Pretty sure Icon specifies to reuse the factory pin if removing the overloads. You use theirs if leaving them in.
    b_r_o likes this.
  14. Sep 29, 2018 at 4:37 PM
    #54
    93yotasr5
    Sacramento
    Even with the overload spring in, the supplied pin does not work.
    crashnburn80[QUOTED] likes this.
  15. Sep 29, 2018 at 4:42 PM
    #55
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    I used Allen head bolts on mine, done it on other packs as well, never an issue
    REDdawn6[QUOTED] likes this.
  16. Sep 29, 2018 at 4:45 PM
    #56
    kystnTRD
    NW Pennsylvania
    2016 TRD Sport 6MT
    The lift is achieved by the arch of the add a leafs. You can use the overload for 1/2" of additional lift but the ride will be stiffer. Saying this from personal experience, I've ran it both ways.
  17. Sep 29, 2018 at 4:52 PM
    #57
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I dunno about that, the overload only comes into play if you’re hauling a lot of weight. If you’re hauling that much weight, the ride is pretty smooth. Unloaded, and the overload isn’t even affecting ride.
    As has been mentioned, removing the factory overload with these AALs results with 10% less payload capacity.
  18. Sep 29, 2018 at 6:57 PM
    #58
    DuboissTaco
    DuboissTaco Well-Known Member
    Josh
    Northern Ontario, Canada
    2017 Toyota Tacoma DCSB Off-Road
    Minor electrical commodities, SDHQ hidden winch mount with Warn Zeon Platinum 10-S, Bilstein 5100s on all 4 corners with OME 885s and Icon Progressive 3-Leaf, more to come!
    I have this kit in the box waiting to install and stumbled upon this thread. I will be checking my center pin immediately!
    Here is a link for the instructions:
    https://www.iconvehicledynamics.com/wp-content/uploads/2016/07/I51100_REVA.pdf
    Not sure if the leafs are capable of being installed reverse or not, but instruction 6 states the longer end from the centering pin is to be facing the rear of the truck. Hopefully both of your add a leafs were installed with this orientation. If not, maybe this could be contributing to your different ride height issue?
  19. Sep 29, 2018 at 8:28 PM
    #59
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Pretty sure the long side is to counter axle wrap
  20. Sep 30, 2018 at 12:00 AM
    #60
    yotatotaco77
    Yeah, negative on that one, the TSB is for 2005-2010 year models, had the dealership confirm that when I got my new centering pins.
