Icon 3 leaf pack problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yotatotaco77, Sep 26, 2018.
  1. Sep 30, 2018 at 12:02 AM
    #61
    yotatotaco77
    yotatotaco77 [OP] Well-Known Member
    Southern Oregon Coast
    2011 Tacoma TRD off-road extended cab
    Bilstien 6112s with 700# springs ARB Deluxe Bull Bar 9k winch Bilstien 5160s Icon progressive 3 leaf AAL
    Even with the overload left IN, their pin will NOT work. You would need another inch of leafs for the supplied pin to work or more.
  2. Sep 30, 2018 at 7:40 AM
    #62
    DuboissTaco
    DuboissTaco Well-Known Member
    Josh
    Northern Ontario, Canada
    2017 Toyota Tacoma DCSB Off-Road
    Minor electrical commodities, SDHQ hidden winch mount with Warn Zeon Platinum 10-S, Bilstein 5100s on all 4 corners with OME 885s and Icon Progressive 3-Leaf, more to come!
    Which is probabaly correct, I’m just suggesting to double check the orientation because if the passenger side was installed in the opposite direction, could this have possibly caused a change in height between passenger and driver side?
    I would expect anyone to have installed both sides the same regardless.. just a thought
  3. Sep 30, 2018 at 9:34 AM
    #63
    Pwhis
    Pwhis Well-Known Member
    Centerville, IA
    2018 DCSB TRDOR
    I bought one of these. Haven’t installed as of yet. Wondering how it works when also using shims to correct pinion angles. Anyone running both?
  4. Sep 30, 2018 at 9:52 AM
    #64
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    There was an actual recall, not a TSB, that covered the leaf packs from 2005-2011. Basically any of the 2+1 packs and certain 3+1 packs were replaced due to the possibility of the leaf breaking and rotating out of alignment and stabbing into the fuel tank. Your truck should qualify based on what leaf packs you look to have in the pictures posted.
  5. Sep 30, 2018 at 9:57 AM
    #65
    yotatotaco77
    The service department at the dealership ran my vin number and said it did not qualify, they were the ones who told me about the recall when I went in to buy new centering pins. They said it was strictly for the models years 05-10. But they ran my vin anyway and said it did not qualify for the new leaf pack replacement. Maybe there was a very select few 2011, idk but they said mine didn't qualify ‍♂️‍♂️
  6. Sep 30, 2018 at 10:10 AM
    #66
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Interesting. There’s probably a manufacture date window it applies to then. My 2011 qualified and had it done.
    For reference, here’s what the determination of good or bad springs is. If yours are the bad type you could try to see if they’ll work with you for the recall even if the computer says you’re not affected.
    yotatotaco77[OP] likes this.
  7. Oct 15, 2018 at 5:09 PM
    #67
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I ran into the same issue yesterday, all set to assemble, and wham, bolt too long, threads too short. Stock pin was a bit short, so I opted to tap threads down the icon pin to where needed, and will cut off top of after install tomorrow. Almost went with the allen head bolt, but not sure how strong they are.
    93yotasr5[QUOTED] likes this.
  8. Oct 16, 2018 at 6:00 PM
    #68
    Killowatt
    If I were to do this again, I'd get correct length pins from the dealer, or use allen head bolts. Guy at Icon said they would be fine. With the overload removed, a 2 1/2" bolt with threads down to the 2" mark, measured from the bolt head.
  9. Oct 16, 2018 at 6:12 PM
    #69
    Wakecoach
    Wakecoach Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    Has anyone ever left the overload in ? I didn’t, but curious about the ride if anyone has experience .
    Since adding a topper line have sagged a little . Wondered if I could add overload back in for a touch of height.
    Or if I should be looking at new leaf pack
  10. Oct 16, 2018 at 7:28 PM
    #70
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    I've ran this setup with and without the overload. It will certainly help with the topper. Expect to gain about 1/2" of height. Ride is slightly stiffer which was my reason for putting it back in. I prefer it that way. With our without my topper on.
  11. Oct 16, 2018 at 7:36 PM
    #71
    Wakecoach
    Kurt
    Great .. thanks for the reply
  12. Oct 16, 2018 at 7:54 PM
    #72
    kystnTRD
    NW Pennsylvania
    2016 TRD Sport 6MT
  13. Jun 19, 2020 at 8:06 AM
    #73
    kevin_ryle423
    kevin_ryle423 Well-Known Member
    Is cutting the icon aal clamp better than cutting the overload spring clamp? Im doing mine soon so I Wanna know which one is better
  14. Jun 26, 2020 at 8:36 AM
    #74
    kevin_ryle423
    Anyone suggestion for this one?
  15. Jun 26, 2020 at 9:15 AM
    #75
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Really doesn't matter, but if you think there might be a chance you ever remove the overload I'd leave the Icon clamp. The parking brake cable can be secured to that thru bolt on the Icon.
  16. Jun 26, 2020 at 10:29 AM
    #76
    kevin_ryle423
    do i have to remove that clip on overload spring completely?
  17. Jun 26, 2020 at 1:49 PM
    #77
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Personally, I'd cut the overload spring Bracket off and drill and tap a hole in the Icon bracket.
    That being said, I have the Icon 3 leaf progressive aal and my centering pin was full thread with a spacer holding it all together.
    Fun project. Although I'm enjoying NOT doing it even more.
    Good luck.:thumbsup:
  18. Jun 26, 2020 at 2:28 PM
    #78
    kevin_ryle423
    Could you send me a picture on how you did it please
  19. Jun 26, 2020 at 2:42 PM
    #79
    Larzzzz
    Larry
    MA
    I can't as I didn't reinstall the ol leaf. As for the job itself; I did this with the springs still installed.
    You need 2 sets of Jack stands; 1 for the truck, 1 for the axle. I jacked from the diff as high as I could go and set stands under the frame. Lower it and make sure you have full droop and then some.
    Jack the diff up a bit and support it on the other set of stands.
    From there, I disconnected the shocks on the axle, loosened the u bolts then took one side off. Use the jack to lower that side off the spring.
    From there, 2 c clamps to hold the leaves together then remove the pin.
  20. Jun 26, 2020 at 7:26 PM
    #80
    gotblika
    Maui
    2015 DCLB Sport 4X4
    yes, grind the rivet head off pound the retainer off the spring the grind rest of rivet shank smooth with spring. I'd also remove the overload retainer.
