Icon AAL problems
Discussion in 'Suspension' started by hedman, Apr 16, 2011.
  1. Jan 26, 2012 at 12:01 PM
    #61
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Mr 2x4 was the one on the other end of the phone when I was installing mine. Maybe he is the one that told me :confused:
    Either way I have barely any axle wrap and I'm always playing in deep sand (the ultimate axle wrap condition)
  2. Jan 26, 2012 at 12:07 PM
    #62
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    FYI I just measured mine. It's 13" from the axel to the end of the top aal front and rear! Same both ways with Deaver. About 1.25" from the clamps on both ends of TSB springs. It all seems pretty symmetrical here? Funny I just noticed some rust on the rear of the aal like maybe they cut some off but the pad is right where it should be? interesting
  3. Jan 26, 2012 at 12:11 PM
    #63
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I thought Dan (Wheelers) said there should be a long side and short side with the Deaver kit?
    Maybe Deaver gave you a kit that actually kits the truck without modification since you bought direct from them? :confused:
  4. Jan 26, 2012 at 12:17 PM
    #64
    HB Taco
    Curt
    could be. Pretty much everything they do is custom but he pulled them out of a rack and there were several others there.
  5. Jan 26, 2012 at 12:39 PM
    #65
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Like I mentioned 1st gen springs are center pin offset (longer springs to rear /shorter to front) The 2nd gen leaf packs I've rebuilt are center pin config'd with eyelett to center pin being equal distance/length whether front to center or back to center measurements the same, & its been my experience so far that adding just about any extra springs will eliminate axle wrap...
  6. Jan 26, 2012 at 2:55 PM
    #66
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Chris is to blame!
  7. Jan 26, 2012 at 4:02 PM
    #67
    Pugga
    Massachusetts
    That's what I heard also :cool:
  8. Jan 26, 2012 at 4:20 PM
    #68
    XXXX
    sKiP
    05 Prius
    John was the guy talking to him :D
  9. Jan 26, 2012 at 4:22 PM
    #69
    Pugga
    Massachusetts
    That's ok, it can still be pinned on Chris.
  10. Jan 26, 2012 at 4:23 PM
    #70
    JDMcQ
    Don't blame the messenger. If you had fed me lunch, I might have been slightly clearer of mind and ignored Chris.
  11. Jan 26, 2012 at 4:40 PM
    #71
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    HEY WTF!!?? What did I do??
  12. Jan 26, 2012 at 4:52 PM
    #72
    XXXX
    sKiP
    05 Prius
    somehow my aal got put on backwards :rofl:
    .....John helped and you did tech support
    then 2 weeks ago I helped another guy and just copied what we did to mine :D
  13. Jan 26, 2012 at 4:53 PM
    #73
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I run the long end forward. Seems to give better control over axel wrap. THats what I said to John when you did yours. DAre you un happy with the ride? :confused:
  14. Jan 26, 2012 at 4:57 PM
    #74
    XXXX
    sKiP
    05 Prius
    Not at all - the opposite actually. I just found it funny today that after almost 30k and countless times offroad I find out it's technically backwards.
    Never had one single issue :)
  15. Jan 26, 2012 at 5:03 PM
    #75
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool! :) Its something Ive been fucking around with for a while. It started when I accidently installed a set backwards, and I was driving along and thought..."Hey...this rides nice!.....And I dont have that dam thump anymore!!"....and went from there
  16. Jan 26, 2012 at 5:04 PM
    #76
    Pugga
    Massachusetts
    Move along, nothing to see here... :anonymous:
  17. Jan 26, 2012 at 5:06 PM
    #77
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:
  18. Jan 26, 2012 at 5:33 PM
    #78
    Pugga
    Massachusetts
    Hey, in my defense, I did at least give you credit for the idea of turning the AAL around to reduce axle wrap. :eek:
    So on a more serious note, does spinning the AAL around actually make a significant improvement on axle wrap? In my head, I can make a case for it helping and it making absolutely no difference. :notsure:
  19. Jan 26, 2012 at 5:35 PM
    #79
    JDMcQ
    Should we all agree to not take Chris' advice on matters of mechanical nature?
  20. Jan 26, 2012 at 5:37 PM
    #80
    XXXX
    sKiP
    05 Prius
    nah....nothing bad came out of it and I can't even be sure why we put it long forward.
    I just remember "white letters up front"
