Icon AAL problems
Discussion in 'Suspension' started by hedman, Apr 16, 2011.
  1. Jan 26, 2012 at 5:42 PM
    #81
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How about just things involving an open flame :D
  2. Jan 26, 2012 at 6:12 PM
    #82
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I believe that his incompetence goes well beyond that.
  3. Jan 26, 2012 at 6:13 PM
    #83
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    that kinda hurts John.
  4. Jan 26, 2012 at 6:33 PM
    #84
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Next time I see him Ill give him a nut slap for you :D
  5. Jan 26, 2012 at 6:37 PM
    #85
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Punch him in the ear. :cool:
  6. Jan 26, 2012 at 6:38 PM
    #86
    XXXX
    sKiP
    05 Prius
    how about a good old dead leg..?
    that usually drops people to the ground
    Oh and BTW it's time to drop a nuke on the fl thread :rofl:
  7. Jan 26, 2012 at 6:43 PM
    #87
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AN ear punch is good....rings for days!!
  8. Jan 26, 2012 at 6:48 PM
    #88
    XXXX
    sKiP
    05 Prius
    that's evil
    and he is usually packing heat when I see him
  9. Jan 26, 2012 at 6:53 PM
    #89
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Jan 26, 2012 at 6:55 PM
    #90
    XXXX
    sKiP
    05 Prius
    if someone punched me in the ear the retaliation would be immediate and not so good.
    if I whack him in the leg he is immobilized so I can run away screaming like a little girl
  11. Jan 26, 2012 at 7:23 PM
    #91
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:.......understood.
  12. Jan 27, 2012 at 4:10 AM
    #92
    JDMcQ
    An ear punch? That's a little extreme, isn't it?
  13. Jan 27, 2012 at 5:34 AM
    #93
    Pugga
    Massachusetts
    Go for the combo, nut slap, ear punch and dead leg, then haul ass (screaming like a little girl optional)! :D
  14. Jan 27, 2012 at 5:37 AM
    #94
    JDMcQ
    Hey! That's not cool!
  15. Jan 27, 2012 at 6:28 AM
    #95
    Pugga
    Massachusetts
    Well, in your case no, not cool. :eek: You gotta do something pretty shitty to earn that combo shot.
  16. Jan 27, 2012 at 6:54 AM
    #96
    JDMcQ
    I didn't do anything at all! Chris is to blame here!
  17. Jan 27, 2012 at 7:11 AM
    #97
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I just tried to help, and pass on what has worked well for me. :(
  18. Jan 27, 2012 at 7:14 AM
    #98
    JDMcQ
    Excuses!
  19. Jan 27, 2012 at 7:18 AM
    #99
    JDMcQ
    In all seriousness, Chris did help us out a lot. We wold have flipped a coin if not for his input. the AAL works fine and that is what matters. instructions of some sort from the manufacturer would have been helpful.
  20. Jan 27, 2012 at 8:42 AM
    #100
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    THEY ARE NOT ON BACKWARDS.
    I have a 1st gen, which have offset center pins (short fronthalves, longer rearhalves). Gen2 Tacos are centered. The Wheelers 3-leaf AAL exactly matches the vehicle its entended for, assuming stock leaf packs (the top AAL leaf is about 2 inches shorter overall than the bottom stock leaf). Deaver does this also. The ends of the AAL, after install, should be about 1-inch from the stock clamps. They line up perfectly. You did look closely at my photo, right? That is a photo of the front of the installed AAL pack. The rear looks just like that, just as I expected. There is no need to remove the stock clamps, as they will never come in contact with the AAL pack, even under flexing.
    If they were on backwards, the AAL pack would overlap the front clamp big time. If someone attempted to install gen2 AAL's on a gen1, or vice/versa, then there would be issues like that. It just wouldn't work.
