Icon aal w/recall oem springs
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by point45, Jan 17, 2022.
  1. Jan 17, 2022 at 2:34 PM
    point45
    point45 [OP] Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Just pulled them today to swap for deaver springs, was not enough lift for my trucks setup. Came off my 05 double cab short bed.
    Had these on the truck for 4 months, approx 800 miles on them. Both the oem springs and icon aal installed at the same time. Bushings and bump stops are new oem toyota as well
    Also have the oem overload spring if you want an extra inch of height but icon does not recommend installing it.
    Everything is installed, no need to cut or take apart your springs, just swap these in. Comes with the oem u bolts but you will need longer aftermarket ones if you want to run the overload leaf.
    $150, local pick up also willing to meet within a reasonable drive. Located in buena park, ca.
  2. Feb 12, 2022 at 1:44 AM
    point45
    SoCal, OC
    05 DCSB TRD offroad
