Icon aal
Discussion in 'Suspension' started by MightyMouse-SCT, Jan 20, 2012.
  1. Jan 20, 2012 at 1:54 PM
    MightyMouse-SCT
    MightyMouse-SCT [OP] Well-Known Member
    Gabriel
    O'SIDE CA
    MightyMouse-SCT - 2011 LT 4x4 Desert Runner
    Long Travel Total chaos kit, fox shocks, smp fab , dmz sua, glassworks, method wheels.
    Was interested in putting a icon aal on . How do you guys like it for normal and desert driving . I normally don't carry things in the bed . Will it soften it up a bit in the desert ? Bottom out more ? Your input is greatly appreciated .
  2. Jan 20, 2012 at 4:06 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I can't speak to desert runs but I love the ride. It does not bottom out easily, even when fully loaded. It's great product in my opinion.
  3. Jan 20, 2012 at 6:02 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Thanks . I've heard good words about the icon aal but just wanted some input from people who actually run them . They are priced on the low side and I'm also looking at a set of deavers but those are pricey .
  4. Jan 21, 2012 at 1:22 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    '13 Tacoma TRD Sport DCLB 4x4
    stock.....for now...
    you mean the 3 leaf AAL kit?
    Subbed for any more opinions. Considering it for my 1st gen....
  5. Jan 21, 2012 at 4:30 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    3 leaf aal is the ony way to go! Very smooth ride on and off road. After a year and a camping trip with heavy equipment it started sagging and bottomes out on speed bumps.....no bueno! Since then I added the overload leaf back in and got softer bump stops as I basically hit them every time. Pretty dissapointed in their longevity though. These are actually the wheelers 3 leaf made by alcan so the icons made by deaver may be different.
  6. Jan 21, 2012 at 5:03 PM
    TacoMX
    Jonathan
    Deltona, Florida
    My bed is almost always empty, and I never haul anything...so I should be okay.
    And I am looking at the Icon/deaver unit.
    I can definitely see how the 3 leaf pack will ride better and help sustain the arc of the pack better and longer.
  7. Jan 21, 2012 at 8:06 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    any of you guys put the 3 leaf aal in when your stock springs were already worn out?
    i don't have the cash for a new leaf pack but my stock ones are sitting flat right now.
  8. Jan 21, 2012 at 8:17 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Yeah I was looking at either the icon aal for $179.00 or maybe the deaver j66 . Both say they add 1.5" of lift Which I like and need to work with my current rear shocks . I'm wondering if the deavers are worth the extra $500 and how long each will last with not much weight in the bed most of the time .
  9. Jan 21, 2012 at 8:25 PM
    Pugga
    Massachusetts
    F-150 Mod
    If you keep the overload leaf in place, the Icon 3-leaf AAL gives you 2" of lift. The 1.5" of lift is figured with the overload being removed.
  10. Jan 21, 2012 at 8:45 PM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Thanks . I'm just seeing that as I'm searching around more . They say to leave in the overload spring also if you tow or keep alot of weight in the bed . Also not to add the aal if your current springs are shot as the aal will be doing all the work . This is primarily my desert truck so I wonder if I should just go with the j66 .
  11. Jan 22, 2012 at 6:20 AM
    Pugga
    Massachusetts
    F-150 Mod
    100% correct about adding an AAL to a worn out leaf pack. It's just a band aid at that point and will wear out very quickly and definitely keep the overload in place if you plan to tow or haul. The 3 leaf is pretty flexible. It does support weight pretty well, but squats quite a bit to do so. When fully loaded, I'm barely on the overload leaf (fully loading meaning pushing 1,000 lbs in the bed).
  12. Jan 22, 2012 at 11:11 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    You've got a new truck so your factory springs should be fine!
    3 leaf it brother!
  13. Jan 22, 2012 at 11:21 AM
    Pugga
    Massachusetts
    F-150 Mod
    OP has a 2010, not new... :confused: Mine's a 2007 with 65k miles and I've arleady replaced the leaf springs twice. You can definitely trash the factory leafs in a couple years.
  14. Jan 22, 2012 at 11:36 AM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    I have both. A 2010 and a 2011 . This is for my 2011 desert truck .
  15. Jan 22, 2012 at 11:38 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    If you want something for the desert, why not go with a custom leaf pack from ALcan or Deaver. Alcan asks so many questions in regards to what the pack should be built for, they can make you a really custom, perfect set-up from what I have heard from their customers.
  16. Jan 22, 2012 at 11:39 AM
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    Yeah I heard about that . I'll look into that also . Thanks
  17. Jan 22, 2012 at 11:41 AM
    08pretaco
    Oliver
    az
  18. Jan 22, 2012 at 6:23 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I hear you.....I've got an 08 and they sucks balls!
    mahaloTaco likes this.
  19. Mar 10, 2015 at 12:24 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Anyone tried the 3 leaf with a set of 06 springs and a cab. I believe the springs are toast. Can these work in the meantime for a year until new springs?
  20. Mar 10, 2015 at 2:46 PM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    Save your money and just pick up some new springs when you can. If your springs are toast already your going to kill the 3 leaf add in no time.
