ICON adjustable w/ UCA's. What and how???
Discussion in 'Suspension' started by Specialist001, Aug 16, 2012.
  1. Aug 16, 2012 at 9:23 AM
    Specialist001
    Specialist001 [OP] Taco Newbie
    Travis
    Lompoc, CA
    Debadged PreRunner
    ICON Adjustable Coilovers, Total Chaos UCA's, Bilstein 5100's in back.
    Good day all. Please excuse my noobness. I bought my 08 PreRunner from a dealership in town and it already came with the ICON adjustable fronts and some kind of aftermarket UCA's. Does anyone know exactly what kind of lift (model #?) and UCA this is and how the hell do you work it?? I'm afraid to touch it because I don't want to throw anything out of wack. It sits pretty high in the front and I want to bring it down to level the truck.
  2. Aug 16, 2012 at 9:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You'll need an Icon spanner wrench to dial down the preload. You will need an alignment afterwards. A local off road shop or maybe a local member might have a wrench you could borrow.
    If you're going down to stock height, you might even consider swapping in stock UCA's and selling off the aftermarket ones. Those are some expensive parts.
  3. Aug 16, 2012 at 9:45 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    Good to know on the wrench. Thanks. But there's no way to keep the alignment myself? And I thought that's what the UCA's did? Anyway, I want to keep all of that on there just in case I want to lift the back sometime in the future.
  4. Aug 16, 2012 at 9:49 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    if you ever come up to slo i have a spanner wrench for you haha. :D
  5. Aug 16, 2012 at 9:51 AM
    Pugga
    Massachusetts
    No, anytime you alter the front end, even if you don't actually remove anything, you should have it aligned. By backing off the preload and making the truck sit lower, the UCA's and LCA's will not operate at a different angle. It's a good idea to have the alignment checked.
    Plus, if you're going to lower the truck down, you should loosen the UCA and LCA bolts anyways, lower the truck, then retighten. This allows the rubber bushings to be at their 'neutral' position when the truck is at the new ride height.
  6. Aug 16, 2012 at 10:36 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    lol thanks man!! I'll keep that in mind.
  7. Aug 16, 2012 at 10:37 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    Roger that. Thanks all! So does anyone know what kind of UCA's those are? I want to do some research on them.
  8. Aug 16, 2012 at 10:39 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    Also, whenever I have to cut the wheel really hard or do a u-turn, a loud dull metal-on-metal sound comes from my front end. I imagine it has something to do with the UCA's? Maybe they weren't fitted properly??
  9. Aug 16, 2012 at 12:24 PM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Pretty sure they are total chaos uca's. There is only one way to install them. So it wouldnt be a fitment issue. My biggest guess for what you're hearing is the tires rubbing on something. You can get a spanner from downsouth motorsports. They are a vendor on this site. Spray the threads with a teflon lube before adjusting as they may be a bit frozen. The collars also have an allen set screw that you need to back out before you adjust them.
  10. Aug 16, 2012 at 7:23 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Depending of your tire size, less lift will cause more rubbing.
  11. Aug 16, 2012 at 7:24 PM
    jandrews
    '09 FourDubDee TRD OR
    No spanner wrench needed. A couple 9mm allen wrenches or steel punches will work fine.
  12. Aug 21, 2012 at 9:43 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    I know for a fact the tires do not rub, they don't even come close. It's a hard metallic "pop" sound. Can't figure it out. Oh well... nothing is broken yet.
  13. Aug 21, 2012 at 9:47 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Sway bar rubbing or cracked bushing.....may need to put some dry lube on the upper control arm uniball and some grease on the bushings?
    That's some of the basic up keep on that type of suspension.
  14. Aug 21, 2012 at 9:49 AM
    Large
    Large Red
    def total chaos ucas without the decals of course.
  15. Aug 21, 2012 at 4:08 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    jack up the truck and make sure the UCA isnt hitting the coil spring one the bottom.. if it is just rotate the sprins a little so it clears
  16. Aug 22, 2012 at 1:32 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Nothing to add here other than a fellow (ex) ammo troop saying :wave:
  17. Aug 23, 2012 at 7:56 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    lol hi! Good to see other AMMO troops around here. Maybe start an AMMO Taco thread??? Yes?? Yes??!?!?! :cheers:
  18. Aug 23, 2012 at 8:00 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    Any particular dry lube you suggest?
  19. Aug 23, 2012 at 8:00 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Are we sure those arent the all pro UCA's I thought they had red bushings too.
  20. Aug 23, 2012 at 8:06 AM
    Specialist001
    Travis
    Lompoc, CA
    Debadged PreRunner
    Thanks for all the input everyone! :cheers:
