Icon and rust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bossman14, Jan 24, 2017.
  1. Jan 25, 2017 at 10:39 AM
    #41
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I went through this before deciding which coilovers I wanted Fox, Icon and King. The interesting thing I dug up is no one really took into consideration the combination of different materials used to constructing the shock bodies. Aluminum by it self which can also be treated is very good against corrosion bc the surface will oxidize and form a protective coating. If damaged it can repair its coating almost immediately.
    For OP instant the Icon body of the shock is steel with CAD coating (Cadmium which forms a white oxidation and is better than zinc coating) and aluminum machined parts.
    FYI Cadmium is a chronic poison similar to lead and mercury so be sure to wash hands after handling the shock body
    Bossman14[OP] likes this.
  2. Jan 26, 2017 at 6:58 AM
    #42
    Bossman14
    Bossman14 [OP] Well-Known Member
    2016 white Tacoma TRD OffRoad access cab
    Stock
    So I got a reply back from ICON and they said they have a 1 year warranty against manufacturing defects, so they said I can send it back and get it "repaired" then go through their claims department to get it done for free. This is such a pain in the ass, I wish they would send me a new shock and I will ship the old one back because the shock is on my daily driver and I don't have another vehicle to drive to get to work. so what do I now??????
    scottalot likes this.
  3. Jan 26, 2017 at 7:01 AM
    #43
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Send it back like they requested, get a rental car for the interim and chalk it up to the price paid for driving a vehicle that is modified with aftermarket parts.
    Or clean the corrosion the best you can, apply fluid film or equivalent and continue driving with reasonable certainty that the rust won't get any worse as long as you keep on it.
  4. Jan 26, 2017 at 7:37 AM
    #44
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Some companies will work with you and do exactly as you said on good faith. Maybe tell them your situation and ask if they can? Sometimes they will.
    98tacoma27 likes this.
  5. Jan 26, 2017 at 7:47 AM
    #45
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Even if they don't on good faith, you can most certainly tell them the situation, pay for a shock out of pocket for a deposit/core charge until you send in your own shock for replacement and they should refund you the deposit/core charge
    Coot83 likes this.
  6. Jan 26, 2017 at 7:51 AM
    #46
    GPsevinSixx
    Ros Angerus
    That's another way!
  7. Jan 26, 2017 at 7:57 AM
    #47
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    That's a bummer OP, hopefully they can work with you like others said. When the time comes, I plan to actually buy a second set of coilovers to swap out when mine need to be serviced. That way I can always have fronts ready in case I need them as my truck is a DD as well.
    Coot
    spiralout462 and scottalot like this.
  8. Jan 26, 2017 at 7:58 AM
    #48
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    See if they will take a deposit and send you a new set then get it back once the claims dept gets your old ones.
    Wampa and scottalot like this.
  9. Jan 26, 2017 at 7:58 AM
    #49
    c4lvinnn
    No need, really. You should just keep the stock suspension. The fronts are easy to swap out.
    MRBOND101 and scottalot like this.
  10. Jan 26, 2017 at 8:01 AM
    #50
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Depends if he is lifted and stuff. In my case though, stock wont work with LT.
    Coot
    c4lvinnn[QUOTED] likes this.
  11. Jan 26, 2017 at 12:14 PM
    #51
    Wampa
    Wampa Well-Known Member
    2016 Tacoma
    Is that Icon Stage 3 corrosion, or just Stage 2?
    ..sorry couldn't pass it up . That sucks though, if you have the funds I'd swap them for Radflo or Fox, send the Icon's in for the claim/warranty fix, and sell them when you get them back. If you do your own suspension work you probably wouldn't be out much in the end. Metal tech frequently has 10% off Radflo and Fox can be had for ~8% off through AutoAnything if you call and haggle your way down. Good luck.
  12. Jan 26, 2017 at 1:18 PM
    #52
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    +1. Never again.
    In OP's case, I would take the shocks off (30 min per side), clean the rust off as best as I could, apply sealant or other protective substance, and reinstall. Then wash and protect them religiously.
  13. Jan 28, 2017 at 8:35 PM
    #53
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    i called because one of my rears was leaking with only a 100 road miles on it. called and talked to a guy and he was just like "yeah, they need to be rebuilt. go to the website and fill out the form. he wouldnt even take my order over the phone. i also asked him about custom brackets because theirs woouldnt work with my bumper. he basically told me i was on my own and to find a fab shop. thats fine but maybe he could have given me some dimensions or templates or something that wouild have helped me make mine. entire call was like 2 mins before i finally let hime get rid of me. maybe it was a busy day or something, no big deal. but i shouldnt have to pay for leaking shocks with 1000 rtoad miles. also on expedition overland youtube channel, theirs broke as well. just not real impressed.
  14. Jan 28, 2017 at 8:57 PM
    #54
    0210
    Vancouver, BC
    Yup. One of my front coilovers was empty of oil within ~5 weeks of being installed. Spent 2.5 weeks waiting for the rebuild. Nothing but incompetence from Icon.
  15. Jan 28, 2017 at 10:04 PM
    #55
    JoshyP
    JoshyP Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    King makes the best shocks I hear.
    OP - You live in a snowy area with a lot of salt in the road? Salt will do that to anything. No matter what brand...
  16. Jan 29, 2017 at 2:13 AM
    #56
    Wampa
    2016 Tacoma
    Eh. I wonder about Icon sometimes. They charge a premium for their components, some of which aren't any better than their competitors. What they do have is an incredible marketing strategy with their "stage" packages, it induces competition about the consumer to "up-stage" if for no better reason than thinking they're getting a better product and/or suspension system without really knowing what's best for their own individual use. I'm sure they make good stuff but their mission as a company seems entirely capitalistic and advantageous. I'll go with old school customer support, competition heritage, and competitive pricing any day.
    Sorry, I may get flamed but the whole "stage" thing and what its induced in the actual Toyota community really erks me. I guess I've been involved in marketing and branding long enough to recognize it. If they offered supreme customer support perhaps I'd feel differently.. at least you'd be getting something extra for buying into their scheme.
    0210 and lose_money like this.
  17. Jan 30, 2017 at 12:03 PM
    #57
    Bossman14
    Stock
    I just got an email back from ICON they can not send me a new one and they told me to fill out a claim then send the shock in to be re-plated/repaired, this is such an inconvenience on my life i wish they would work with me more. The reason i went with ICON is because I heard they were the top of the line but i guess i was wrong. I will never buy from ICON again and i will suggest to others not to buy as well.
    0210 likes this.
  18. Jan 30, 2017 at 12:04 PM
    #58
    Bossman14
    Stock
    No snow here, just rain, seattle wa
  19. Jan 30, 2017 at 12:04 PM
    #59
    Bossman14
    Stock
    stage 3
    Wampa[QUOTED] likes this.
  20. Jan 30, 2017 at 12:55 PM
    #60
    lose_money
    lose_money Well-Known Member
    Dean
    2016 MGM TRD OR 4x4 MT
    King 2.5, Icon AAL, SCS Ray10 16x8
    That's sucks, sorry op
