Icon C/O w/ 3" spacer lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rollinn, Sep 7, 2009.
  1. Sep 7, 2009 at 4:20 PM
    Rollinn
    Rollinn [OP] Well-Known Member
    Vegas
    06 Prerunner sport
    Icon 2.5 c/o,TC uca, bhlm mod, nav, etc etc
    Got a question for you guys, I was going to install bilstein 5100's w/ a 3" spacer kit and TC uca's w/ a 2" rear block kit.. I was going to set the bilsteins at the min. lift @ .85"
    I was told this would be the MAX as the uniball would be maxed out in one direction..
    Now I just picked up a pr of Icon coilovers-
    So can I install a 3" spacer on top of the Icon c/o and just crank it up around 3/4" lift to keep the ride nice?:confused:
    I know I can crank it up to get 3.5" of lift by itself, but I cant imagine the ride to be anything close to stock which is a main concern for me..
    Thoughts everyone?
  2. Sep 7, 2009 at 4:22 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    i would say just ditch the spacer and just use the icon's as your lift
  3. Sep 7, 2009 at 4:24 PM
    Rollinn
    Vegas
    06 Prerunner sport
    dude I would ideally love to, but the ride is my main concern.. And need the 3.5" for my 285/70/17 xtreme m/t tires.. Im torn right now
  4. Sep 7, 2009 at 4:27 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    you will probably need to get new uca's if you want a good ride also. i am not lifted so someone else will have to help ya cause i do not know how the ride would be.
  5. Sep 7, 2009 at 4:29 PM
    Rollinn
    Vegas
    06 Prerunner sport
    I have Total Choas upper control arms-so not an issue there
  6. Sep 7, 2009 at 4:30 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    thats good. well hope the best for ya and pics when your done
  7. Sep 7, 2009 at 4:38 PM
    Rollinn
    Vegas
    06 Prerunner sport
    shouldnt expect a crap load of answers on labor day when everyone is probably shit faced!!! Always remember the liver is evil-it must be punished!!!
  8. Sep 7, 2009 at 4:59 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I think you oughta just set the coilovers to 3". I am pretty sure you will have a better ride with your coilovers set at 3" than you will with them at 3/4" and a spacer.
  9. Sep 7, 2009 at 5:03 PM
    Rollinn
    Vegas
    06 Prerunner sport
    i think since the spacer is a billet spacer that sits on top of the c/o it doesnt have any preload on the spring so it shouldnt change the ride at all correct?
  10. Sep 7, 2009 at 5:08 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    If I'm not mistaken, you can't add the blocks on top of the ICONS. I have the donahoe (older version of the ICONS) and remember reading that you can't add anything on top of the coilover...
    Mine are set at 2" of thread showing between the top of the adjustor nut and the shock collar and they ride like a dream with the UCA's. If I were you, I'd sell the blocks and put the money toward a good set of UCA's then crank up the coilovers. You can level out the front of the truck while you're at it and the guys at ICON said if you have aftermarket UCA's that you can actually max out the height with 2.5" of thread showing between the adjustor nut and the shock collar. This should get you pretty darn close to 3.5" of lift that you're looking for.
    Good Luck!
  11. Sep 7, 2009 at 5:14 PM
    Rollinn
    Vegas
    06 Prerunner sport
    hey drrabbit I do have the Total choas uca's that I will be installing w/ the c/o- but i believe in order to get the 3-3.5" of lift they will be cranked out.. And as i have never owned a set of icons or dr before i dont know how they will ride cranked all the way up.. I am assuming that they will be somewhat harsh..
  12. Sep 7, 2009 at 5:22 PM
    Rollinn
    Vegas
    06 Prerunner sport
    quite the pickle we r in here huh guys.. Someone must have tried and screwed up royally and is willing to give the secret from there unsuccessful efforts
  13. Sep 7, 2009 at 5:22 PM
    jonny
    jonny Betty White Edition Heep ZJ
    x2
    if you bought the coilovers, set them at 3" and lose the spacer. my spacer does whet i need it to do....but once i get my priorities straight...gonna upgrade to spindles and 5100's
    CO's and a spacer lift......wouldnt try it dood
    if you DO go ahead with it, report back with your thoughts/concerns
    thanks and good luck man!
  14. Sep 7, 2009 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If lift AND ride is your concern, get a set of spindels. The route your considering, useing spacers on top of CO's, is silly. You run the risk of destroying your CO's if going off road.
  15. Sep 7, 2009 at 5:40 PM
    jonny
    yupp
    Camburg spindles will give you 4" of lift
    (prerunner only)
  16. Sep 7, 2009 at 6:26 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    you can add a spacer on top without a preload. You'll just need to go to the hardware store and get longer grade 8 bolts. I have 3/4 spacers on top oh my DR/Icon coilovers. I also have camburg UCA's but it should be ok without, just don't crank the coilovers and also do the 3inch spacer. Also remember to add a washers and locktight.
  17. Sep 7, 2009 at 6:53 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    I'd say throw out the spacers and just get spindles as mentioned above. Then you can just keep the Icons at stock height and it will ride good or even great.
  18. Sep 7, 2009 at 6:54 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    do this! thats what I will do when I get the $ for spindles. soften up the icons and get lift from spindles, then a shackle flip to help level it. Blocks and spacers are junk IMO
  19. Sep 7, 2009 at 7:00 PM
    Rollinn
    Vegas
    06 Prerunner sport
    well so many opinions-its getting the thinking wheels turning.. Keep the comments coming- i will make a final decision here soon.. I will let everyone know what route i go and send pics as well..
  20. Sep 7, 2009 at 7:32 PM
    Rollinn
    Vegas
    06 Prerunner sport
    hey bro on your c/o what did you set the lift at? your a 100% correct there should be 0 preload as its on top of the coilover itself.. My only concern would be too much lift, anything over 3-3.5" would bind the uca upper bolt to one side.. How much total lift do you have and how is the ride on your setup? also what lift did you do in the rear? do you have any pics of your ride:D
