ICON Coil Overs Ext travel 2nd gen
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by izquik72, Dec 8, 2011.
  1. Dec 8, 2011 at 7:53 AM
    izquik72
    izquik72 [OP] Well-Known Member
    Northern AZ
    2002 SR5 DCSB 4x4
    shell, grey wire, turn signal relocate bumper ordered lift OME ordered
    Wanting to purchase a longe range Scope for my 7mm Mag.
    Selling the 2nd gen Ext Travel Icons. $1155 new
    I purchased these used from a member last year I put them on 9 mo. ago
    He put 10k on them i have maybe 2k.
    Make offer or trade for:
    Leupold or Zeiss scope
    Swarovski or Nightforce = my coilovers+ca$h
    OR.....$old split shipping
    3 leaf Add a leaf $old
    After
  2. Dec 8, 2011 at 10:06 AM
    bcroach78
    bcroach78 Well-Known Member
    TN
    2010 Crew cab TRD L/B S/C
    I believe it is $825 with split shipping.
  3. Dec 8, 2011 at 10:15 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Bump! Good man ,sounds like a quality scope for some long range monster coues, instead of a suspension :)
    I am right there with ya brother!
    Azbackcountry
  4. Dec 9, 2011 at 2:24 PM
    shaneoo
    shaneoo New Member
    SOCAL
    05 PreRunner sr5 debadged
    bumper,lights,fender NEED coilovers UCA and rear shocks
    pming you
  5. Dec 9, 2011 at 3:17 PM
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    so these are good for how much lift?:confused:
  6. Dec 9, 2011 at 3:38 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Bump for a great product!
  7. Dec 11, 2011 at 5:49 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    0-3.5....I ABSOLUTELY LOVE MINE!!!!! Bump for an excellent front setup, but you will need a uniball UCA...
  8. Dec 11, 2011 at 6:35 AM
    bcroach78
    TN
    Why do you need a uniball UCA?
  9. Dec 11, 2011 at 6:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Because they are extended travel CO's. The OEM ball joints cant handel the extra droop they give.
  10. Dec 11, 2011 at 6:47 AM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    ^^^This...you will brake your OEM UCA ball joints because of all the weight of the hub, spindle, new coil, ect...will all be on the ball joint of the UCA when the wheel is off the ground at full droop...
  11. Dec 11, 2011 at 6:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not the weight, as the LCA bears the weight of everything, but the range of motion the OEM ball joint allows.
  12. Dec 11, 2011 at 6:59 AM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    And the young padawon learns again...
  13. Dec 11, 2011 at 2:14 PM
    DaWillDaBeast
    DaWillDaBeast Well-Known Member
    Will
    Colorado
    05 Tacoma 4x4 with some goodies
    Things
    Would you be able to use a set of aftermarket ball joint UCA's with these? Like the Light Racing or the Camburg ball joint UCA's?
  14. Dec 11, 2011 at 2:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe the LR UCA's, but not the Camburgs, as they use stock ball joints. Even the LR UCA's might break.
  15. Dec 11, 2011 at 2:29 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    yes, LR UCAs will work. i have LR and extended travel icons. i can jack the truck off the ground, take out the lower shock bolt at full drop and push down on the lower arm and get another inch out of downtravel. granted the CVs start binding at that point....
    so yes, you can run them, and the shock will still be the limiting factor.
  16. Dec 11, 2011 at 2:36 PM
    bizjettech
    bizjettech Well-Known Member
    Sunny Florida
    what are the P/N's of these? Why does the icon web site show them for 2005 - 2007 only?
  17. Dec 12, 2011 at 4:17 AM
    Joeymgd78
    Joeymgd78 Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
    are these still available im intrested in buying
  18. Dec 12, 2011 at 7:14 AM
    izquik72
    Northern AZ
    2002 SR5 DCSB 4x4
    Yes they are still availiable.
    Thanks for all the bumps guys.
    I am pretty sure this thread is for the Icon coilovers that I have for sale.
    There are numerous threads Under "suspension"
    (http://www.tacomaworld.com/forum/suspension/)
    where you guys can discuss Upper and lower control arms.
  19. Dec 12, 2011 at 8:17 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Camburgs ball joints are re-positioned to allow more travel, so they should work! Camburg told me they would work with their ext travel coilover and yield 10.5" of travel! Hope that's true!
  20. Dec 13, 2011 at 8:16 AM
    izquik72
    Northern AZ
    2002 SR5 DCSB 4x4
    Added before and after photos.
    Anybody need a x-mas present
