Icon Coilover Issue
Discussion in 'Suspension' started by J_Hacker, Jan 16, 2017.
  1. Jan 16, 2017 at 3:07 PM
    Large
    Large Red
    You forgot to put the misalignment spacer on the driver side c/o, or it's installed wrong somehow
  2. Jan 16, 2017 at 3:10 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    ^ This is something to look out for. Same as with uniballs, the standard FK Bearing ones are steel. The Icon are made by FK, but are stainless.
  3. Jan 17, 2017 at 6:35 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    What did Icon come back with? The rotation seems normal, the lateral sliding on the top mount seems like a problem.
  4. Jan 17, 2017 at 6:39 AM
    J_Hacker
    J_Hacker [OP] Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    Hey Jerry,
    The spiracle bearing in the upper and lower mounting positons are designed to pivot. If there’s additional play outside of it being able to rotate then they may be in need of replacement but this will generally not be the case with the parts having so few miles on them. There is no warranty on bearings or bushings as they are wearable parts.
    Thank you,
    BRIAN JACOBS SALES
    PH: 951-689-4266 X.112 FAX: 951-689-1016
    BRIAN@ICONVEHICLEDYNAMICS.COM
    WWW.ICONVEHICLEDYNAMICS.COM
    [​IMG] [​IMG]
  5. Jan 17, 2017 at 6:43 AM
    Arcticelf
    Gladiator
    can you post us a video of the motion you're seeing?
  6. Jan 17, 2017 at 6:44 AM
    J_Hacker
    I can take a video at some point. (on shift emt currently riding around on an ambulance)
  7. Jan 17, 2017 at 6:44 AM
    J_Hacker
  8. Jan 17, 2017 at 6:45 AM
    Arcticelf
    Gladiator
    I hope you have a quite and boring shift :)
    J_Hacker[QUOTED][OP] likes this.
