Icon coilover leaking.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dan8906, Aug 27, 2017.
  1. Aug 28, 2017 at 8:42 AM
    Dan8906
    Dan8906 [OP] Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I agree, I am pretty disappointed, and honestly its probably more like 6k. I was thinking about when i ordered them in December, but i didn't install them until march.
  2. Aug 28, 2017 at 8:48 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Sucks OP, I have seen some discrepancies with Icon front and rear shocks with mixed results. I hope this can be handled accordingly as 6k is def still pretty fresh man.
    <3<3<3<3 @90yota don't want you to miss out if there is an event.
    90yota likes this.
  3. Aug 28, 2017 at 8:52 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Icon will deny everything. I would just switch to Kings and never look back.
    Silver02Taco, Coot83 and 90yota like this.
  4. Aug 28, 2017 at 8:57 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    As a fellow King advocate, lets see what Icon says before we just bail on the issue. At the same time, if you want some of the best out there from a progressive (soft at slow speeds, stiffer at faster speeds) feel then King is a strong answer. I want to be confident for you, but Icon has looked the other way before. Def let us know what they come back with.
  5. Aug 28, 2017 at 9:01 AM
    Kelvin
    Kelvin Wheeeeee
    I wish the OP good luck then. They speak to me like I ride the short bus.
    Coot83[QUOTED] likes this.
  6. Aug 28, 2017 at 9:01 AM
    Dan8906
    Daniel
    Concord, California
    Does king make an adjustable coilover for first gen tacomas?
  7. Aug 28, 2017 at 9:08 AM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Coot83 likes this.
  8. Aug 28, 2017 at 9:09 AM
    Sodom
    Sodom Well-Known Member
    New England
    2001 Xtra Cab SR5 4x4 3.4L 5-Speed Gold
    Rust
    Yes, Fox does too.
    Coot83 likes this.
  9. Aug 28, 2017 at 9:17 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I run 32's (265/75's) with the stock wheels on my 04 doublecab. I had 5100's on the middle setting and they rubbed on the rear frame a bit at full lock.
  10. Aug 28, 2017 at 9:21 AM
    Dan8906
    Daniel
    Concord, California
    Im running a 275/70/17. I have wheel spacers to clear the frame.
  11. Aug 28, 2017 at 9:26 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Wouldn't surprise me at all brother.
  12. Aug 28, 2017 at 9:33 AM
    jbrandt
    Justin
    What are your old shocks you have that you kept?
    You can probably run them. Will they rub? Probably. But it beats not being able to drive it at all.
    The rebuild intervals on the shocks really depend on how much abuse they see. If you are out desert running every weekend, you'd probably want to rebuilt them annually, if not more often. The pros I'm sure rebuild theirs every weekend.
    There are more threads dedicated to that subject, but from what I remember lurking around those threads before getting my Kings, annual rebuilds seemed pretty common for the guys who like to pound on their trucks. I just installed mine, so they haven't even seen dirt yet... :(
  13. Aug 28, 2017 at 9:38 AM
    doorsidedown
    doorsidedown Well-Known Member
    I've got about 6k on my icons so far and they've been great, knock on wood. I'm invested now so I'll rebuild them when it comes time.... but my taco isn't my DD so that helps.
    Speedytech7 and Coot83 like this.
  14. Aug 28, 2017 at 9:39 AM
    jbrandt
    Justin
    This.
    Airing down is for traction, not shock longevity.
    The problem with sustained high temps is that it tends to cook your oil, meaning you need to rebuild them more often, hence resi's with their higher oil volumes for better cooling.
  15. Aug 28, 2017 at 10:20 AM
    #35
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Def some key info for the more aggressive off roader, but not sure if the OP fits the bill completely as he might be more of a recreational off roader. My guess would of been more to the 4-5 year mark or 50k before a rebuild.
  16. Aug 28, 2017 at 10:20 AM
    #36
    Dan8906
    Daniel
    Concord, California
    I do light wheeling on the weekends mostly to get to a campsite, every once in a while I do some harder stuff. Overall, Im pretty easy on the truck. Most days it sees an 8 mile round trip work commute.
  17. Aug 28, 2017 at 10:22 AM
    #37
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    When my icons took a shit I swapped them out for Kings. Best decision I ever made
    Coot83 likes this.
  18. Aug 28, 2017 at 10:26 AM
    #38
    eon_blue
    Azusa, CA
    All you need to air down is a screwdriver and a cheap gauge to monitor the psi.
    Yes they do, I just bought them from Headstrong last week. $990 for the pair (+ taxes). They're pretty affordable for 1st gens compared to other options.
    Coot83 likes this.
  19. Aug 28, 2017 at 11:58 AM
    #39
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    For some of you that have used both Icon and King...
    I currently have a set of Icons with 650bs coils. I recently got a deal on some used Kings that need a rebuild that I'm think of doing so and swapping out. I've heard that Kings ride a little smoother and also I would like to run 600lb coils with only having the weight of a 2.7L up front.
    What do you think?
  20. Aug 28, 2017 at 12:01 PM
    #40
    Dan8906
    Daniel
    Concord, California
    Do you have a winch bumper? skids? thats the big thing that requires a bigger spring
