Icon Coilover question corrosion/install
Discussion in 'Suspension' started by mhagio, Aug 2, 2009.
  1. Aug 2, 2009 at 6:30 PM
    mhagio
    mhagio [OP] Active Member
    San Diego
    06 DC Silver 4x4
    two questions with respect to my Icon coilovers
    1) Is it normal wear to have corrosion on the coils after about 2 months? I am wondering if the installer scratched them during install. Do i need to worry about this?
    2) At the bottom of the cylinder, the black part has a split about 1-2" wide. It looks like on one side (passanger side) the gap is facing toward the rear of the truck as opposed to the other side (driver side) its facing toward the front of the truck. Does this matter? I'm a little concerned the steel rod from the shock is exposed to more elements when facing toward the front.
    Thanks for the advice
  2. Aug 2, 2009 at 11:32 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    The is only one way to install the coilovers, and that is the right way. So if it is different from side to side, that is the only way it can be done.
  3. Aug 2, 2009 at 11:40 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Post some pics.
  4. Aug 3, 2009 at 12:36 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    that gap is there so you can pull that spring plate off to replace the coils during a rebuild or swap out different spring rate coils...
    it won't fall off or anything and they don't have to line up with each other...
  5. Aug 3, 2009 at 8:55 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    post up some pics so we can get a better idea of whats up
