Icon Coilovers question
Discussion in 'Suspension' started by yonosoyasi, May 4, 2010.
  1. May 4, 2010 at 8:42 PM
    yonosoyasi
    yonosoyasi [OP] Member
    SoCal
    04 DC Tacoma
    I want to get some Icon C/Os, that were offered to me for $799.
    But they are extended travel, Can I install them even though I dont have aftermarket UCAs?
  2. May 4, 2010 at 8:44 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    its more recommended that you put after market uca's so that you can get the potential out of the coilovers,and take advantage of the wheel travel but i am pretty sure there are people here that have the extended ones without aftermarket uca's
  3. May 4, 2010 at 8:45 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You can, but guess what your next purchase should be in the following few months.
  4. May 5, 2010 at 7:45 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    you'll be fine as long as you dont fully droop them. if you do that you'll max out the UCA ball joint and eventually cause it to fail. i wouldn't hit up dirt until you got your aftermarket UCA's.
    $800 for a set of good condition used icons is a good deal. as long as they dont need a rebuild.
  5. May 5, 2010 at 10:44 AM
    yonosoyasi
    SoCal
    04 DC Tacoma
    thanks for the input guys!
    And I definitely wanna get some aftermarket UCAs...probably going with LRs!
  6. May 5, 2010 at 4:39 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i dont think those will solve the problem because they still use the stock ball joint. they only correct alignment.
    you have to go w/ a uni ball style CO (camburg or TC) because the ext travel CO's combined with the uni ball UCA allow for 1" extra down travel. the LR will prob still max out the ball joint same as stock.
    again, i'm not 100% on that so double check w/ other people
  7. May 5, 2010 at 4:43 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Yep thats what happend to me, i bought the fox extended travel and ran stock UCAs for about a months then got some camburg 1.25" UCAs. Yea don't fully droup the suspension out, my balljoints were starting to bend from offroading.
  8. May 5, 2010 at 4:46 PM
    Dellosa89
    Brian
    Murrieta CA
    First Pm TRICOMA about the built right UCAs i saw them inperson and very impressed with how they look.
    http://www.tacomaworld.com/forum/members/tricoma.html
  9. May 7, 2010 at 2:34 PM
    yonosoyasi
    SoCal
    04 DC Tacoma
    he has pics...here they are!
    they look nice and beefy!
    cheaper that the Camburgs too!
    I want!
  10. May 10, 2010 at 11:59 AM
    yonosoyasi
    SoCal
    04 DC Tacoma
    guys should I get a Diff drop...when I install the C/Os?
  11. May 10, 2010 at 12:03 PM
    Trigger
    Trigger Well-Known Member
    ^^ Anything over 3 inches is recommended for a diff drop. Alot of people with the Icon C/0 don't. It's up to you. I would go ahead and throw it on there just to be safe.
  12. May 10, 2010 at 12:08 PM
    yonosoyasi
    SoCal
    04 DC Tacoma
    Im thinking of just going 2.5" of lift!
    so still do the diff drop?
  13. May 10, 2010 at 12:54 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    No
  14. May 10, 2010 at 5:34 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    Can i ask u were your gonna get the coilovers for $799?
  15. May 10, 2010 at 6:33 PM
    yonosoyasi
    SoCal
    04 DC Tacoma
    From someone local that sold his truck.
  16. May 10, 2010 at 6:34 PM
    yonosoyasi
    SoCal
    04 DC Tacoma
    will I need extended brake lines with the ICON C/Os?
