Icon Coilovers Vs Icon Extended Coilovers?
Discussion in 'Suspension' started by Eesh, Feb 4, 2010.
  1. Feb 4, 2010 at 12:31 AM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    Whats the difference? What are the pros and cons? They are both the same price.. I don't get it?
  2. Feb 4, 2010 at 12:38 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    The extended travel shock will allow for a 1" more of down travel, The reason why its the same price is because when they are putting them together they they leave out one of the spacers on the shaft in the shock. But you do need a aftermarket UCA for the extended travel. But if you buy the non extended travel you can pull apart the shock and remove one of the spacer and have a extended travel shock.
