Icon coilovers with stock UCA's ?
Discussion in 'Suspension' started by wfbont007, Mar 15, 2009.
  1. Mar 15, 2009 at 3:23 PM
    wfbont007
    wfbont007 [OP] Well-Known Member
    Southern NJ
    06 DC
    I know I probably will get bashed for this! I have been saving for TC UCA and Icon coilovers. I hardly ever go offroading. If I add just the CO's without the TC UCA's and run with the stock UCA's, will it be that big of a difference? I know that my alignment will be out slightly.
    Many will say keep saving and get the TC UCA, I know.
  2. Mar 15, 2009 at 3:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your caster will be about .5* depending on how high you lift.
    Spec is 2.4* to 3.1*
    This means your truck will wnder, and you will have mad bump steer.
  3. Mar 15, 2009 at 3:53 PM
    cfenn
    cfenn Well-Known Member
    San Antonio, Texas
    PreRunner
    TRD exhaust,TSB, 5100's on the front, 884 springs, Total Chaos UCA, 5100's on the rear, Wheelers HD rear springs , Nitto 285/70/17's on MB TKO 17x8.5's
    Which is always fun especially when it is windy
  4. Mar 15, 2009 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Mar 15, 2009 at 4:47 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    If you were to get the extended icons then yeah i would highly suggest in uca's i see setups with no aftermarket uca's and the ride isnt that bad, just keep saving.
  6. Mar 15, 2009 at 5:18 PM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    You can always get the coilovers now and the UCAs later. Just make sure you keep the lift under 2" inches and you will be fine. Tons of people here run Billy 5100s set at 2.5" inch lift without UCAs.
  7. Aug 20, 2018 at 2:19 PM
    Vibarra78
    Vibarra78 Member
    Vincent
    2018 Tacoma TRD Off Road
    any info on running Icon Coilovers and UCA with stock rear suspension?
