Icon Delta Joints worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loretta, Aug 2, 2021.
  1. Aug 2, 2021 at 4:07 PM
    Loretta
    Loretta [OP] Well-Known Member
    Joey
    2016 Tacoma Double Cab Long Bed
    So I’m about to pull the trigger on some Icon Delta Joint UCA’s. But just wanted to see if anyone had an opinion on a comparable UCA that maybe wasn’t as pricey. I’m down to spend for what will be a great UCA for a long time which is what these look like but if anyone has two cents on the matter toss it in the hat.
    Joey
  2. Aug 2, 2021 at 5:48 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Depends on what you plan on using them for.
    Skydvrr likes this.
  3. Aug 2, 2021 at 5:51 PM
    Bishop84
    Bishop84 Well-Known Member
    My go to is SPC arms, delta joints are cool but the joints wear and in salty areas they tend to fail a lot sooner than SPC arms. Probably half the cost as well.
    Skydvrr likes this.
  4. Aug 2, 2021 at 6:23 PM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    I ran Deltas on my last T4R. They were great, silent and well built. Headstrong recommend Dirt King as well. I may go DK on this truck and save a few bucks.
    DavesTaco68 likes this.
  5. Aug 2, 2021 at 8:30 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    No, you dont need anything more than a trad moog style unless you plan to race and service ball joints all the time.
    mr.rick, Loretta[OP] and HoytK9 like this.
  6. Aug 2, 2021 at 9:18 PM
    Loretta
    Joey
    Honestly I’m getting new UCA because I want to upgrade to 33’s. I have 2.5” OME lifts and need UCA to account for them. I’m on forest service road and off-road almost everyday.
  7. Aug 2, 2021 at 9:28 PM
    Loretta
    Joey
    Damn those are super cheap. What’s the deal with these?
  8. Aug 2, 2021 at 9:51 PM
    JoeCOVA
    Joe
    Colorado Springs
    I recommend SPC, JBA or other UCA that accept a moog ball joint. They are reliable and strong with little maintenance and you can easily buy replacements at a local parts store.
    Abject4x4 and FishnTx like this.
  9. Aug 3, 2021 at 12:43 AM
    3GTNATE
    3GTNATE Well-Known Member
    Central Coast, CA
    2021 Cement TRD Off-Road 4x4 DCSB
    Was looking into these as well awhile back, but went with SPC for adjustability and maintenance.
    71tattooguy likes this.
  10. Aug 3, 2021 at 3:43 PM
    mr.rick
    mr.rick Well-Known Member
    Rick
    2021 Voodoo Blue TRDOR
    I ran the Total Chaos UCAs on my 4runner. Living in Colorado with all the mag-chloride they spray on the roads... I got 18k miles on the first set of uniballs before they got sloppy and required a replacement, then the bushings went to shit.... you're looking at about $200ish bucks including the tool. For what my experience was worth.... a set of SPC or JBA's would be my choice. The ball joint is sealed, and will last a lot longer against the road grime. I started chasing noise//squeaks on those TC UCAs after about 5k miles and finally just gave up on them after 25K, I am no expert but having to drop the whole front suspension out every oil change to grease/clean and check everything is annoying. .... if you do decide on a uniball upper... I would suggest something that has a sealed top or dust cover for it.
    JoeCOVA likes this.
  11. Aug 3, 2021 at 3:53 PM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    JBA uses Mid 90s Chevy C/K2500 ball joints that just bolt onto the UCA. Makes repairs while traveling or on the trail super easy as replacements are available at any common parts stores.
  12. Aug 3, 2021 at 3:58 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    SPCs or SPCs repackaged in Mevotech boxes. Their adjustment capability means you can set the LCA cams to maximize tire clearance and minimize trimming.
  13. Aug 3, 2021 at 6:18 PM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    Check out Camburg as well, more choices the better.
    Invid likes this.
  14. Aug 3, 2021 at 6:34 PM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    I've got about 100k on my uniballs. It seems like I'm under this thing every 3 or 4 weeks douching the bushings and uniball with tri-flow. Next rebuild I'm changing them to the deltas because they are a little easier to maintain. One day I'll finally figure out where the squeak is coming from...
