Icon ET coilovers and 33s/ BS / Daily red romper build thread**
Discussion in '1st Gen. Builds (1995-2004)' started by kylevanhulten18, Feb 12, 2017.
Thread Status:
Not open for further replies.
  1. Feb 14, 2017 at 4:52 PM
    #61
    gbollom
    gbollom Well-Known Member
    Weatherford Tx
    01 xcab TRD 4x4 5spd
    Once I got it out of the UCA I used a rental ball joint tool from oreilys with their 4x4 adapter kit. On the BJ stud i placed a cut down 7/8 deep socket. Worked like a charm after 3 hours of struggling with it before i got this system figured out
    kylevanhulten18[OP] likes this.
  2. Feb 14, 2017 at 6:06 PM
    #62
    kylevanhulten18
    kylevanhulten18 [OP] Well-Known Member
    Think I'm going to go with a angle grinder on the uca bolt lol seems The easiest. Was the ball joint in the spindle really that challenging with the rental tool??? Im 2wd btw. Imma hit the drawing board in the AM.
  3. Feb 14, 2017 at 6:06 PM
    #63
    kylevanhulten18
    Any reccomendations on Lug nuts for my new pro comps 252 series ??
  4. Feb 14, 2017 at 6:09 PM
    #64
    gbollom
    Weatherford Tx
    not once i got the stupid adapter set that i wasn't aware of until later. also had to get creative with the 7/8 socket, the parts that came with the press wouldn't fit the stud of the BJ properly
  5. Feb 14, 2017 at 6:36 PM
    #65
    kylevanhulten18
    Updated Thread:). Turning into a build thread/bs/me struggling on every part of this truck lol. Thanks again for all the input guys!! Keep it coming. Grinding these damn joints off in the morning !
    quetzal and boostedka like this.
  6. Feb 14, 2017 at 8:49 PM
    #66
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    My steelies take these. Yours will too.
    rj95lss likes this.
  7. Feb 15, 2017 at 3:05 AM
    #67
    harper7
    harper7 Well-Known Member
    Gary
    Tulsa/Claremore OK
    00 Imperial Jade 4x4 TRD,01 TRD 5sp
    I have run these Gorilla nuts for years with aftermarket wheels as they have an extended thread section.They get more threads on the studs especially with thicker hubbed aftermarket alloy wheels.More expensive but you get what you pay for,they are solid and with durable paint.
    Sicyota04 likes this.
  8. Feb 15, 2017 at 7:28 AM
    #68
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I run these too.
  9. Feb 15, 2017 at 9:52 AM
    #69
    Digiratus
    Roaming the PNW
    The RedHead
    Are you guys running these with steel wheels? Pretty sure those will not work stock alloys or steel wheels. They are designed for aftermarket allow wheels.
    harper7[QUOTED] likes this.
  10. Feb 15, 2017 at 10:20 AM
    #70
    kylevanhulten18
    ive been looking at these they have a shank so will they be good with my steel pro comp??
  11. Feb 15, 2017 at 11:33 AM
    #71
    harper7
    Gary
    Tulsa/Claremore OK
    I think Digiratus is right. They are probably too much shank for steel wheels and made more for thicker hubbed alloys.The acorns he linked or for spline drive and steel wheels ,these.....
  12. Feb 15, 2017 at 1:46 PM
    #72
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I'm using them on 16x8 Method Double Standards.
  13. Feb 16, 2017 at 2:28 PM
    #73
    kylevanhulten18
    UPDATE! Control arms in! Are they supposed to move when torqued to reccomenrdrd ft lbs? Torqued them and they're on there pretty solid. Kind of hard to move up and down by hand
  14. Feb 16, 2017 at 2:47 PM
    #74
    kylevanhulten18
    image.jpg Well theyre in!! Ended up taking a hacksaw to the ball joint bolt Lol. But yea I'm stoked! Now just confused on what coilovers goes on what side. There's two part #s on the icons anyone have any input for that???
    jules04taco likes this.
  15. Feb 16, 2017 at 2:52 PM
    #75
    kylevanhulten18
    One says 26330 the other is 26331
  16. Feb 16, 2017 at 3:10 PM
    #76
    kylevanhulten18
    Anybody :( lol
  17. Feb 16, 2017 at 3:11 PM
    #77
    Sicyota04
    Morgan
    California
    04 DC 4x4
    As long as they don't have reseviors it doesn't really matter what side goes on which. But in the directions it says the way you can tell is the Nitrogen fill Valve should be faced 30 degrees towards the front of the truck. Mine came w/ a Driver's side sticker and passenger side sticker on the top of where it mounts to the top of the shock tower. I asked Icon if it really matters and they said no other that the nitrogen fill valve should face forward. 1st pic is driver's side and 2nd is passenger
  18. Feb 16, 2017 at 8:31 PM
    #78
    Digiratus
    Roaming the PNW
    The RedHead
    Don't torque them yet. Wait until the wheels are on and the weight of the truck is on the ground. Torque them at ride height.
    You did grease up the bushings real good before assembling right?
  19. Feb 16, 2017 at 8:46 PM
    #79
    kylevanhulten18
    Yes greased them good! Everything installed truck handles fuckin good... just need to put on new wheels ant tires and get an alignment.... but come to find out I'm leaking coolant everywhere . So have to find the culprit of that now -_-
    Digiratus[QUOTED] likes this.
  20. Feb 16, 2017 at 8:56 PM
    #80
    kylevanhulten18
    Seems to be the seal on the tank of the radiator...I'll get pics tommorrow it's coming from the top under the tabs and around there of the tank.. is the rubber seals on the tank fixable or am I looking at a new radiator
Thread Status:
