Icon ET coilovers and 33s/ BS / Daily red romper build thread**
Discussion in '1st Gen. Builds (1995-2004)' started by kylevanhulten18, Feb 12, 2017.
Thread Status:
Not open for further replies.
  1. Feb 16, 2017 at 9:07 PM
    #81
    kylevanhulten18
    kylevanhulten18 [OP] Well-Known Member
    I'll update pics of the new suspension in the AM;) thanks for the help guys! You saved me a lot of stress
    99SuperTaco4x4 and NightProwler like this.
  2. Feb 16, 2017 at 11:20 PM
    #82
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Probly a new one. I would be sure it's not the cap tho, or the hose. Other than that, it may be more possible you have a crack in the upper tank. That's more common. It's hard to see.. I have yet to hear of them leaking from the seal. Not sure how that works tho if that's even possible. Either way, if its not the cap, or even hose, Probly a new rad.
    FirstTimeFirstGen likes this.
  3. Feb 17, 2017 at 12:31 AM
    #83
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Autozone loans specialty tools like that for free, you just need to leave a deposit and they return the full amount. They have tools that you need
  4. Feb 17, 2017 at 1:11 AM
    #84
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Looking good. What radiator are you going with? I need a new one for my 98 I think - current one has 100K and it seems to be leaking around where you said yours was.
  5. Feb 17, 2017 at 6:51 AM
    #85
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    New radiator, in the old days the top and bottom tanks of the radiator were metal, and those you could remove and replace the big seal in between the tanks and the core. Not a viable option anymore. You can get a Denso on Amazon for a hundred bucks. Not sure of other online stores prices.
  6. Feb 17, 2017 at 9:15 AM
    #86
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Do they make one for the 5vz standard transmission? I've only see or auto on parts sites and Amazon. :confused:
  7. Feb 17, 2017 at 9:21 AM
    #87
    cruiserguy
    Elijah
    SEKS
    For a first gen? If so, just use the automatic radiator and leave the caps on the lines of the radiator that would otherwise be connected with the transmission lines.
  8. Feb 17, 2017 at 10:14 AM
    #88
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yes. I didn't know if there would be fitment issues between the two setups. Thank you.
  9. Feb 17, 2017 at 10:33 AM
    #89
    cruiserguy
    Elijah
    SEKS
    :thumbsup: No problemo homie
  10. Feb 17, 2017 at 10:38 AM
    #90
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Where are the pictures at???
  11. Feb 17, 2017 at 1:59 PM
    #91
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    X2
    kylevanhulten18[OP] likes this.
  12. Feb 17, 2017 at 4:04 PM
    #92
    kylevanhulten18
    They're coming ! Lol had a couple things to do today. Prepping the fenders for 33s etc.
  13. Feb 23, 2017 at 2:40 PM
    #93
    kylevanhulten18
    IMG_1695.jpg Soon boys..... as in Saturday
    jules04taco, boostedka and -40 like this.
  14. Feb 23, 2017 at 2:41 PM
    #94
    kylevanhulten18
    The hankooks are beefy!
  15. Feb 23, 2017 at 5:57 PM
    #95
    rj95lss
    rj95lss Well-Known Member
    Robert
    Pinelands, NJ
    '92 HZJ73 - 1HZ diesel RHD
    SOA with OME, Lockers, 37's, ARB
    Don't use these. I tried them on Procomp's and they will not work without modding them or the wheels (which is a bad idea). They require at least .62 for the shank to slide through the wheel and you only have .585 inside the holes in your wheels. Take out a caliper and measure, you will see what I am talking about. Use the ones @Digiratus said, I use those too, they work fine as long as you are not trying to run any spacers at all.
    Digiratus likes this.
  16. Feb 23, 2017 at 8:09 PM
    #96
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    In the daily thread the OP was advised to use these: [​IMG]
    Personally, I think this was bad advice and believe these VVV are the correct ones. It is what I use on my steelies.
  17. Feb 23, 2017 at 8:21 PM
    #97
    kylevanhulten18
    What's the difference between the two?? I got the top ones above
  18. Feb 23, 2017 at 8:22 PM
    #98
    kylevanhulten18
    They seem similar
  19. Feb 23, 2017 at 8:24 PM
    #99
    Digiratus
    Roaming the PNW
    The RedHead
    Top ones, the splined type are for aftermmarket alloy wheels.
  20. Feb 23, 2017 at 8:30 PM
    #100
    Digiratus
    Roaming the PNW
    The RedHead
    @rj95lss nailed it. The splined type are for the smaller stud holes found in alloy wheels. They will be too small for the stud holes on the steelies.
    Steelies use the Acorn style with the 60 degree chamfer.
    If you don't believe me, call Wheelers and ask them which of the 2 types work with your wheels.
Thread Status:
