Icon extended travel coilover swap
Discussion in 'Suspension' started by northern cal, Feb 8, 2013.
  1. Feb 8, 2013 at 6:00 PM
    northern cal
    northern cal [OP] Active Member
    bay area
    tacoma TRD
    Going to swap my procomp 3" stuff for Icon all around on my 4.0 double cab. I now have just over 23" hub center to fender. What are others with Icons and OME Dakars getting for measurments?
  2. Feb 10, 2013 at 2:53 PM
    northern cal
    bay area
    tacoma TRD
    Anything?
  3. Feb 10, 2013 at 4:50 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    There adjustable set them to whatever you want .
  4. Feb 10, 2013 at 10:51 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Theres a thread somewhere with measurements.....try a search under "Icon measurements"? You can adjust where you want but 3" is usually 23" and wouldn't go above that if you want a good ride and down travel....I lowered mine to what I think is 2-2.5" and have 22.75". Just trim so your tires fit and enjoy a smooth ass ride!
  5. Feb 10, 2013 at 11:24 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    im putting my icon extended travel stuff on tomorrow. currently i have the toyotec w/ eibach setup. i went beyond the .85 recommended threshold for these and put the c-clip to 1.75. 1.6 (eibach) plus 1.75 (notched billies)= 3.35 supposed front lift. from the center of the hub to the bottom of the fender measures 22 1/2 (driver) and 23 1/8 (pass). now i know its looked frowned upon but i can attest, that this setup rode super smooth, i liked it a lot, but i want to fix the taco lean. tomorrow im gonna crank the coilovers to the max of 3.5 front lift. ill keep you guys updated.
